V16DAF's Cup - RS2'd/B14/Wilwood/2118
  172 cup RS2 - 330ci
Very jealous of the workshop mate, you are a lucky man!
Good job on the pipe work too. PTFE tape should have been fine. Did you use enough and tighten them up enough?
Is the workshop at your house on somewhere else?
Cheers, yeah I used 5 rolls in total, still didn't seal. The pipe threader I have is a manual one, so it might be doing slightly different dimensions to the joints? I also tightened them FT but still didn't work, as you can imagine I was gutted when they leaked in places. Yeah it's on the farm mate, so only 50 yards from the house :approve:
Keith185
Alan quoted around 7 days for delivery, I'm quite excited TBH. I may spray the interior as well, same colour as the outside of the car.
I would if you have the patience, would just make it that much more 'finished' imo. Great garage, wish one at Mam and Dads farm was that tidy xD
  172 cup RS2 - 330ci
Thanks Keith, This shed used to be a pig shed. There were walls inside splitting different groups, I blocked up the outside walls, knocked down the internal walls and cut a big space for the door at the front. This shed has took me hours to complete, even made the pit myself -
  172 cup, Impreza P1
Very good work mate. I've got a farmer mate and he's the same with sheds and doing all the work himself.
Still very jealous to the stage I know want to be a farmer so I can have a shed like that.
  172 cup RS2 - 330ci
All the gear, no idea ;-)
  182 cup / Audi s3 8L
quality read mate, car looks all good. I just stripped out my rb 182 cup, i've also got a set of bimarcos in, but my side mounts are slightly to wide so have currently got spacers in as dnt want to strain and crack the seat or bend the side mounts. How do the side mounts on your seats fit? What subframe / side mounts did you use? and where did you get them from? Sorry if this info is in the thread did kind of flick through. Cheers
  172 cup RS2 - 330ci
Hi,
Thanks for the comments, my side mounts and subframe are both OMP, got them from Demon Tweeks. Mine also didn't fit, I drilled new holes in the subframe and made them fit. Really poorly designed these OMP subframes
Hi,
Not sure who made my subframes and side mounts as they came with the seats but i had to use spacers inbetween the side mount and seat as the side mounts were to wide for the seat.
hadnt actually finished writing then but the cpu just posted it! Have been looking for a subframe and side mounts that are not universal but specifically designed for the bimarcos and the clio.... have yet to find anything. Are your side mounts tight to the seats?
  172 cup RS2 - 330ci
Yes mate, but only after I drilled additional holes in the subframe
  172 cup RS2 - 330ci
So the cage arrived last Friday, the welds and quality are great TBH. It's going to be painted white by myself within the next few weeks, hopefully it will go well with the 2118's
  172 cup RS2 - 330ci
Got these for a very good price from mytyres.co.uk - just under £250 delivered for 4 x 195/50 r15's
Going to pick up the paint tomorrow so I can get on with the car, I have a few days off this week :cool:
  172 cup RS2 - 330ci
Got some bits and bobs today -
High build primer in grey
Honda Chapionship white for the top layer of the roll cage
Mondial blue metalic paint - to spray the inside of the car
2k winter activator
2k hardner
2k thinner
And a headlight restoration kit
Gonna be a busy week. :approve:
  172 cup, Impreza P1
2k winter activator
2k hardner
2k thinner
If you don't mind me asking, how much did that little lot cost and where did you get it. I need similar for my car and not sure how much it costs.
With the winter activator, what temps can you spray at?
  172 cup RS2 - 330ci
Taken exactly from the invoice -
High build primer in grey (1 litre) - £10.95
Honda Chapionship white for the top layer of the roll cage (500 ml) - £12.82
Mondial blue metalic paint - to spray the inside of the car (1 litre) - £32.95
2k winter activator (1 litre) - £9.85
2k hardner (1 litre) - £8.99
2k thinner (1 litre) - £4.95
All plus vat, got it from Chirk Auto Paints by Wrexham
As for the temp of the winter activator I'm not sure, I'll just try and pick a day where there is no frost about
  172 cup, Impreza P1
Thanks for that. Look forward to seeing how you get on.
  172 Cup & K20 Ph1
Forgive me for not reading all of the thread, will you be painting the entire of the interior white or just the cage? Cheers
  172 cup RS2 - 330ci
So I sanded the cage today, with 600 wet and dry paper. Took 3 hours, it's smooth and ready now. I got the paint ready and turned out the spray gun had packed in :banghead: It was ancient any way and I never stripped it down for cleaning really. I've ordered a gravity fed one from eBay including a cleaning kit. I'll take extra care with the new one.
Cage as it stands -
  172 cup RS2 - 330ci
Had a bit of time free today, so I removed the front seats and harnesses. Put the cage in, went in easily from the passenger side. Placed the cage exactly where it looked level. Marked the holes with a pencil and used a small drill bit first and then a larger one. All 10 holes line up perfectly, so next step is to get some spreader plates and it will be ready to fit. Hopefully the new spray gun will be with me tomorrow. Pics below -
  172 cup RS2 - 330ci
new gun arrived today, sadly I did'nt get a chance to use it. Tomorrow is on the cards though
  172 cup RS2 - 330ci
Did the primer coat this morning -
And I've done 4 coats of white this evening, it needs one more to finish it off. It looks good, iphone pics don't do justice really
  172 cup RS2 - 330ci
I finished the last coat on the cage last Thursday, in between coats I was grinding the unnecessary brackets off inside the car -
It looks so much tidier now. Yesterday I removed the seat frames and the top dash, I need to remove the lower part of the dash this week. Plan is to remove the big sound deadening that is tucked behind the dash. Then I need to mask inside of the car and key the surface ready for painting.
