where is the ECU located on the 1.2 16v engine?
Car  Mercedes C200,Clio R.I.P.
recently i found an ECU looking box on the back of the airbox?
after i removed it i found anoily substance at the bottom of it.
this a normal thing?
its back on the car now mate but there is no ECU on the battery at all.
I thought it was strange having it on the back of the engine.
at the back of the engine.
underneath the metal box (metal box is a protector for the 2 large loom connectors)
This applies to the 1.2 16v
2001 - 2005/6 i think - the new style 1.2 16v has it again near the battery
FredYozzasport said:
its "cooled" by the air inside the plenham, its bloted to the back of the plenham
thanks guys now why would there be an oil gunk on the bottom of it?
yeah on the bottom of the ECU there was a Oilly dirt gunk on it. as for your second question of
"is it potting securing the wiring?"
i dont understand you at all mate :(
thats normal, the oil from the engine is kicked out the breather pipe into the plenham and is then burnt off by the engine, nothing to worry about
Yup its proper crap......also by having a carbon bonnet or a normal bonnet with a dodgy water seal
Water leaks and drips onto the frickin ECU wiring !!! causing havoc.
