Where to run my aux lead too..? Peoples ideas?
  BG DCI
Just got my MT Audio lead through which has the box and then male female leads going to an aux..
Just wondered where people put the box and where they run the lead to..?
Thinking of running it down near the cup holders and have a hole for the male female to go through the plastic!
daveski
I ran a 3.5mm jack through the ashtray (drilled a little hole in the bottom of it) then when I wasnt using the cable it was hidden away.
  BG DCI
I had one with the box attachment at the end of the cable from the HU.
Ran the cable down the back and taped the box to the inside of the plastic on the right of the passenger footwell, ran the actual aux cable up through the bottom of the ash tray and into the cup holders!
Seems a good setup and dont know how else with the size of the box and placement to make it easier to get the male and female lead to be easily removable!
daveski
I drilled a hole in the glovebox for mine and had the box in the glovebox (mine had usb, ipod and 3.5mm) and only ran the 3.5mm one down if I wanted to use my phone or something.
Hoofy
  Chase Racing Clio
I managed to get hold of a female aux plug, spliced the output audio lead into it and stuck it to the left of the gearstick. I thought it turned out nicely, would recommend it.
  172
the above along with just a female jack dash mount are next on the list of items to be made available for these aux in interfaces.
