Green Track Cup - Back To Basics
Re: Road/Track 172
Looks very mean on track.
Do you not like the car? Giving Morgan a shot?? :eek:
:rasp: @ Morgan!
Re: Road/Track 172
:rasp: @ Morgan!
Haha had to destruction test the engine I built out somehow, only joking he took it easy on the car.
Yesterday showed up how much the car now really needs a diff , as it was pointless in the wet.
Totally for got to take the front plate off as well to aid cooling but the temps were fine all day, was worried with it being high comp now it would run hot.
Re: Road/Track 172
Hard to say as I've change a lot on the car over the winter and been about 6 months since I've drove it on track, but it did feel very planted through the corners once the track dried up.
Re: Road/Track 172
:rasp: @ Morgan!
I was fair with it, not my toys so I won't break them.
Thanks again for the shot, its a different beast all together from my last two. I can't comment on the RC kit as it was such a difference with less weight, different suspension etc.
I'll get some videos up when I get a chance from that Clio cup train :)
Re: Road/Track 172
neil a best photo of your car i took yesterday
Neil's cup by W33 BRL, on Flickr
if you want a print let me know
Re: Road/Track 172
No problem Morgan will hopefully give you a push to get your own track/race car finished. I was just glad it was faultless all day after all the changes and engine build over winter.
Re: Road/Track 172
Yip will be giving them a try on the road and if they don't break in i will take them off and fit another set of A048's to the speed lines. Locking up at 110 heading into the hair pin wasn't fun.
Re: Road/Track 172
I'm getting just over 110 now in this new one John when I'm solo on both straights. Mental when you think 300bhp cars are getting similar.
Re: Road/Track 172
You'll not be doing 110. Fastest I ever got was 103 and we've all got the same car essentially.
Check with gps or a vbox and you'll see how far off 110 you really are.
Re: Road/Track 172
Ok 100+ I was just going off a glance at the speedo before getting on the brakes, and seen 110 a couple of times.
Re: Road/Track 172
You need to put your foot down Stevie boy ;)
One of the first laps I looked at. Granted not 110 but easily achievable.
Re: Road/Track 172
Or grow a pair! Either way, fair play!
Also, if I'm reading that correctly, you were mowing the lawn at 78mph. :rasp:
Re: Road/Track 172
Around about. I'm usually 5-10mph quicker through the bottom of Duffus than at the apex. I was doing 80 at the apex when I spun at the days end :headno:
Re: Road/Track 172
Updated spec list
Engine
Jenvey bodies 140mm trumpets
PEC 12.8:1 pistons
ED cams
Cat cam valve springs
Ported phase 1 head
Supertech valves
Peco injectors
Omex 600 ecu
ARP rod bolts
Breather catch tank
182 manifold
K-tech cat link pipe
Stainless power flow system
K-tech engine mounts
228.9 bhp and 176.9 ftlb
Suspension
Konigsport coilovers
Roll centre kit
KTech top mounts
Front strut brace
Rear strut brace
Full front end black series bushes
Black series dog bone
Wheels/brakes
15" pro race 1.2's
15" pro race 2's with A048's
15" 2118's with AD06's
Brembo front discs/ferodo DS2500 pads.
Dot 5.1 brake fluid
Goodridge braided hoses
Interior
6 point Oreca cage
Flocked dash
Oreca steering wheel
Sparco Evo 2 seats with 4 point harnesses
Fire extinguisher
Carbon fibre doorcards
Fully stripped and painted interior
Battery in rear
Poly carb windows and rear screen
Oil temp and pressure gauges
PMS shifter
Body
Carbon bonnet with aero catches
Front bumper with aero catches
Gutted tailgate with aero catches
Fiber glass doors
TRS tow eye fitted front and rear
Cup racer cooling ducts
Vented bonnet and bumper
So much for a cheap track toy
:headno: and really could do with a gripper diff now.
Re: Road/Track 172
Over the weekend i did two track days at knockhil, a 4 hour open pit on Sat and a 2 hour open pit on Monday . The car was faultless both days bar the oil temp getting a little hight but Ive just bought an oil cooler to sort that .
Here is a video from the Monday night. I backed off near the middle of the vid for a lap to let temps drop.
http://youtu.be/Vq9oXgQxLp4
Re: Road/Track 172
Was seeing just over 130 but not sure how accurate the gauge is. Im not 100% sure on the oil as it was changed when the car was in for mapping.
Re: Road/Track 172
Not done any more mods to the car as I've been busy ,sorting out a storage space for the car and trailer. So this week was spent fencing off a section of my garden and fitting a roller door to the back of my garage to allow access to get the car and trailer out of the way.
Before
After
Re: Road/Track 172
That really confused me looking at the pics there Neil and not reading the text. :o
So you have a through garage with doors at either end. Nice idea.
Re: Road/Track 172
Yes I did have my hot tub behind the garage but never used it, so sold that last month and made a parking space for the track car. Now just trying to get the floor cleaned up as 4 years of abuse has made a mess of the tiles. Hopefully by next week it will be looking lot more like it did in the second pic :p
Re: Road/Track 172
Did another track night at Knockhill on Tuesday with a bunch of guys from the Focus owners club, so was 100 bhp down on most of them but the little clio still held its own .
Really need to do a brake fluid change and could ideally do with harder springs of my konigsports , until i get a better set of coil overs.
Also ended up with another set of wheels with 2 new RSR's fitted , but need another pair to replace the Toyo's.
Re: Road/Track 172
Thanks a lot its going really well just now and seems to be reliable, thats 4 track days now since I built the engine and its not even used a drop of oil.
I love this little ST it handles well, and now its over 300 bhp it goes well too.
