AlexW's Driveway Antics :)
  Many.
Busy bee then?!
As always!
Glad to see my old PAS pump being put to good use!
Was a relief to hear it fire up without any PAS pump whine!
Loving the intercooler! I need one in my life! How much?
Cheers, I love it too.
I don't really know the full cost, but intercooler was circa £50, plus boost hoses to mate up to the standard 80 pipework, but with yours being a 65, it'll be more expensive.
Looks good alex i must say.
Cheers dude :)
  Many.
Yesterday I got a new battery for ventura's PH1. Went for an 027 which has a bit more cranking amps, and is slightly taller (Non issue with the battery box)
Now starts first time, everytime. MOT Thursday!
Then onto today/tonight. Had a bloody terrible day at work, loads of problems and stuff, but soon solved that by heading down to Ashford, Kent... To view, and then buy this!
HMS Derv Destroyer... Whats this? lol It leaks.
Its a bloody awesome car, £450, T&T'd until November, drives lovely. Duel mass flywheel rattles, and it has a few minor faults such as passnger window not working.
Poss the best car I've ever bought lol
GrahamS
  335d
Should have come in for tea!!!!
Which mcdonalds is that? I recognise it.
Laguna looks clean.
  Many.
Laguna looks clean.
I was in a rush by that point, circa 8pm. Only got home at 10ish.
Ashford I think? Not a clue tbh!
Its not bad, certainly for £450! lol
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
s**ty throttle flap thing. controlled by vac solenoid. MENT to smooth out the engines air velocity..... ( dont know the exact thing it does or its name but i know its not needed lol )
ive took the one off the megane courtesy car at work. also that engine looks like evey other 1.9.... covered in oil and engine cover foam s**t !
only one thing to say ! TOOOOOOOOORRRRRRRRQQQQQQQQQUUUUUUUUUEEEEEEEEEEE :evil:
  Many.
Exactly what I thought it was, That'll be getting fucked off then.
Its actually very oil-free apart from that valve, its obviously had a minor boost leak on the front pipe at some point, but thats been solved and its all nice and dry.
I do hate that yellow s**t. Gearbox is good aswell!
Thats the air cut off valve iirc. Can get a new seal for them.
What I thought, That'll be gone ASAP!
welshname
I was under the impression it's to help when turning the engine off for some reason. I may be wrong but I'm sure that's what I was told.
  Many.
I haven't got one, first thing I did on it when I collected was rip the engine cover off lol.
I'll get one tomorrow.
  MK1DTi/vivaro/corsa
its open/closed til the vac builds up, then the little diaphragm thing adjusts the angle of the flap.
i actaully dont know properly what its ment to do. other than i think its like swirl flaps in a BMW derv engine. all smooth running buls**t.
  Many.
Yay Laguna fwiend
:D
Sounds pretty gay. I guess it must be naturally open? Deffo sounds like it has a boost leak, so probs missing out on some power there! Plus it smokes a bit.
Yeah I can see exactly where this is going! Now trying to figure out if I need anything that it has!
Indeed, I had already dropped a couple of hints, more to come for those that are a bit slower.
Cracking car for the money mate.
Is indeed...
  MK1DTi/vivaro/corsa
i would say so. i didnt play much attention to it, i just ripped it off whilst i was doing the egr blank. dont forget you now have a VNT turbo. i thought the meggy had a leak but its just the vnt noise. little smoke is probs all the s**t built up over the years from the egr/ turbo/cat.
good thrashing will sort that ;) ( like you havent allready :p )
  Many.
Yeah I'll be blanking the EGR while I'm there again, fit the EGT sensor again too. I knew it had a VNT from the way it drives and revs, tis good.
Yeah I reckon it could probs do with another service too, but it'll obviously get that.
Belts easy enough to do on these? I guess same locking tools as the 1.5?
Exciting times.
GrahamS
  335d
Tools are the same. Of course I've never done a belt but I remember the kit being advertised for both.
You best not turn back! I maybe able to help you if you ever need a hand just give us a shout!
i meant sell the clio DCi, of course it was in jest. Oh & I fixed that boot solenoid last night encase Joe didn't tell you, old one was dead as a dead thing :)
  Many.
Belts the same but you have to lock the pump up aswell.
Its more easy than the 1.5 lol
Ah good.
Nice work. You literally don't stop!
I know lol, don't have time to stop.
Might be next weekend that I want some assistance. Ill let you know.
And ahh good, he hadn't said yet. I'll give you some cash when I see you next.
The laguna dynamique dci 1.9 a turbo waiting to go bang Alex :(.
New turbo last year! Should be good for a few years yet.
Here's the best of an engine. Looks tiny in the Laguna. HMS Derv Destroyer
  Many.
Looking forward to seeing that in a Clio. Are you looking to up the power from it while you're doing/or after the swap
Plan is to get it running at standard ish power, get a few miles down, then get power upped.
Aye what's it good for power and torque wise?
Friend put a 1.9td from a megane into his mk1 Clio years ago and it flew along nicely!
I'd love 200hp & 325+ LBFT. which should be do-able, however I'll probably kill the Pk6 gearbox.
  MK1DTi/vivaro/corsa
That pk6 box will handle near 400Nm of torque
I should know as someone's got a lag' estate dci 1.9 on TDOCUK running that with bmw parts / pd 150 manifold ( made to fit ) and some rather special turbo :)
Tiu can probably f**k most of the pipe work off tbh. Run them nicely routed.
I keep looking at the dti 1.9s do tempting to mechanical injection on in a Clio .....
  Many.
oh Good! Let's see if I can push it past that.
I need to get on there.
Yeah all the boost pipes will be black silicone and hard pipes where required.
Get it done!
  MK1DTi/vivaro/corsa
It'll be a guided missile by the time I've finished finding him better pumps/injectors/turbos :D
think I'll need some more power from somewhere to keep up.....
