K20 powered 172
Chambers_RS
  Clio 172 Cup&Leon K1
Yeah all the fuses good that side too. I reckon it's starter and I'm chasing my bloody tail.
Chambers_RS
So new starter still didn't cure my issue.
So brought a few other items to tidy things up a bit.
PMS exhaust is here now too :)
I've also removed my ktec exhaust and ktec decat so they're for sale now.
Chambers_RS
It's not a stealth exhaust, it's the recessed system. not sure how much as the previous owner has cut and sleeved part of the exhaust. Made it easier to get off and I'll supply a new sleeve. I'll get some pics
Chambers_RS
Few bits done over the weekend. Best bit I got it running :smile:
Fitted the oil pressure switch for me gauges.
Just need to finalise the location of it.
PMS Exhaust fitted too
The hanger is abit some for the prima racing mount tho.
Chambers_RS
Oil pressure switch in its location.
Ordered some powervamp battery cable and a redtop charger.
Hopefully this will solve my starting issue.
Charger in operation also can see the cage is lose, as I'm moving it further back slightly.
Chambers_RS
Cleaned the Leon tonight as at a wedding tomoz.
Just a quick 2 bucket wash, dry and hand polish with Autoglym Rapid Detail.
Ignore the missing jacking covers lol car badly needs claying and machine polish but still shines nicely
Reflection shot on me iPhone
Clio wise I've started ordering bits for a rebuild over winter, suspension wise atm but will move onto the engine too.
Might make a spec list as so I know what's what I reckon.
Dave LM
  PH1 172
Sorry if I've missed it, but what was causing the starting issues? I'm just doing a battery relocation at the moment on my 172, so looking to avoid any pitfalls.
Akay
  Clubman Cooper S
Hi mate, any chance you can tell me the distance of the end of the backbox silencer to the bracket bolted on the rear for the exhaust? I need something similar to align my Ktec recessed and only have 40mm to play with. Did you have to cut your bumper again?
Cheers.
Chambers_RS
Cheers.
The distance to the aluminium mount or the extra mount that PMS have added?
Yeah had to recut the bumper. Currently making a carbon panel to tidy it up
Akay
  Clubman Cooper S
Sorry, the distance from the back of the backbox (not the tailpipe), to the metal on the car that the extra PMS mount bolts on to.
Car is absolutely awesome by the way, I wish I had the seemingly unlimited funds that you do :p some real quality kit and workmanship going on here!
Chambers_RS
Haha I seriously don't have unlimited funds wish i did haha.
I'll have a look tonight as I'll be in the garage tonight trying to figure out why I suddenly have no compression :(
Akay
  Clubman Cooper S
Thanks mate, Im trying to get my ktec recessed to align and I think Im going to use a similar method to PMS.
Oh dear that doesnt sound good!
Chambers_RS
No probs mate.
Nah doesn't sound good at all. Compression test see what's what and then pull the engine out if all isn't well haha
Chambers_RS
Car is absolutely awesome by the way, I wish I had the seemingly unlimited funds that you do :tongueout: some real quality kit and workmanship going on here!
Here you go bud
It's just over 90mm from the back box it's self to the metal part the extra mount bolts too.
Hope that's right and helps.
The ktec exhaust I took off mine was a lot bigger and heavier than this PMS system.
Akay
  Clubman Cooper S
Thanks matey, as I thought the Ktec backbox sits further forward :(
Chambers_RS
Thanks matey, as I thought the Ktec backbox sits further forward 😧
Yeah thought the same.
I'd just make the bracket solid. So it bolts to the car and then just weld the bracket directly to the back box rather using a rubber mount
I originally used spacers to move that rear bracket further away from the back box as it knocked on braking/acceleration. PMS kindly cut the bracket down making it about 10mm shorter. Im guessing its due to the 182 manifold pushing the exhaust system further towards the rear bumper. fyi
Any picture of you mount sonny, I have the exact same problem you had stated above
Chambers_RS
Put the front bumper back on last night and placed the passenger seat in place to make it look more like a car
Can't decide whether to pull the box and lump out for a refresh now or use and abuse it for a little while. I really want a standalone and custom loom making but struggling to find someone near who's willing to do it.
Chambers_RS
Yeah I know, I had beaniesport lined up to do. Was going to go down omex600 and a race dash2 line but they've decided not to make looms for the forseable future :(
Least not doing that I was able to bag a cup box with diff :) silver lining and all that lol
I wanted all the UCH gone mainly. What can you do then mucka?
NorthloopCup
Yeah I know, I had beaniesport lined up to do. Was going to go down omex600 and a race dash2 line but they've decided not to make looms for the forseable future 😧
Least not doing that I was able to bag a cup box with diff :smile: silver lining and all that lol
Well from what I've seen of some of their looms that was possibly a blessing in disguise also mate. They may well do looms to suit budgets though, so this would explain the quality of the one I saw.
I've just stripped my original cup loom back and it's getting ready to be re-covered with proper raychem dr25. Obviously mines a bastardisation of the cup and 197 loom. Just need to finish it!
I'm running the gen90 ecu as well to keep it looking neat. Not a fan of piggybacked ecu's one bit.
Im still running the UCH with Gen90, and trimmed my engine loom down to bare minimum (no VVT, lumbar sensor wires etc) as they are all redundant now.
How you going to pull the box, out the top with engine or drop subframe?
Chambers_RS
Maybe, the looms I've seen in their own cars (white mk1 Clio/yellow 106 gti) and in my mates Saxo have been/look awesome. All covered and plugged etc. haven't seen any others tho so.
The wiring is so complicated on these bloody things. I was thinking of putting a ph1 loom in as I read there not canbus? Not sure if that's true tho lol but then would need DBW sorting lol
I just hate all the wires under the dash and fuse boxes etc.
maybe I should just fit the rs2 and get the standard ecu mapped and use it lol.
Chambers_RS
Does the gen90 come with a base/standard map so you can start the car?
I seen in your thread you've trimmed the interior loom down, did you have any issues cutting the wires?
I seen people having issues who have done.
Not sure yet on the box, thinking I pull the engine out fit some arp bolts and clean the bay.
How do you do it mate, out top?
NorthloopCup
Yeah I don't doubt that at all mate. The one I saw though was poor to say the least.
Nah your not going to achieve anything by fitting a ph1 loom mate, other than causing yourself unnecessary grief. Trimming these looms back is fraught with danger as well. I've seen more failures from people attempting to trim the loom back than I've seen success, and having done the job on my own cup the weight savings are minimal.
Definitely worth getting it mapped and using it though. That way it gives you the chance to see if you feel it needs any additional upgrades elsewhere.
Oh and engine and box out the top is piss easy mate. Bit of a jiggle to do, but substantially easier than dropping the subframe etc imo.
