Interior strip out, footwell ideas?
Now I have my cage I've decided to go a bit more hardcore with the interior, ditch the carpets and any other bits I can live without and paint the bare interior. I'd like to see what you've done with your footwells, sitting in the car the strengthening rib that runs towards the brake pedal feels a bit awkward......do you just live with it and use grip tape or have you needed to install a false floor/footrest?
imprezaworks
  Mk5 Golf GTI :)
i just live with it tbh. I had looked into like a plate of some sort to make it look a bit neater.
NorthloopCup
I've just got strategically placed grip tape in mine. I also kept the strengthening rib in there as its there to help prevent your ankles snapping in the event of a heavy frontal impact.
Dave LM
  PH1 172
I painted my drivers side floor with some truck bed liner paint I got from Halfords. I have previously used the gripper tape, but it started lifting when it got a bit wet.
The painted floor has the same feel of the gripper tape underfoot.
Greeny.
  440i + 182
I just bought generic grip tape from eBay, its ok and cheap, does the job but it's starting to rip it with little use due to the lack of a proper flat surface to stick it to I would imagine.
massiveCoRbyn
  Several
My Escort F2 car has a piece of alloy sheet that is bent to form a little step up an then forms a perfectly level floor, with grip tape applied to it.
It's worth noting that once you take the carpets etc out, the floor might actually end up feeling a bit low. I noticed that in my rally car when I first got it, so am fitting a foot rest to lift the floor a bit. Depends how thick the carpets and sound deadening are though!
massiveCoRbyn
  Several
It can be a lot cheaper than you think now, especially for relatively small bits and pieces. I want some door cards for my Escort but they can get a bit pricey it seems.
imprezaworks
  Mk5 Golf GTI :)
Saw that. To keep costs down I will probably end up with the carbon affect, similar to what I linked
NorthloopCup
Mine with strategic grip tape - it's been fitted a good while now and it's also seen plenty of use. No ripping!
Excuse the s**t pictures! It's dark in the garage and difficult to picture!
Use a hairdryer to form it around the creases is my advice.
