Clio 220 PH2
				Having the door cards at the rear helps as you can imaging giving the back a cleaner look. You will need to channel the wires over the rear wheel arch and down to where the old front seat belt used to be that allows wires to go to the other side of the car and to the multi plug by the passenger foot well.Not answering for Dan, but he asked the exact same question I wanted to! I'm going to run 'lightweight' rear door cards, so those little panels that cover the hole. But also want to hide all my wiring.
Never done anything wire related before. Own a soldering iron thats never been used, so I guess I'm almost there 😂
I will grab lots of pictures for you both and then it's a bit easier to see rather than me waffling on haha
But a soldering iron is good you may need that if chopping begins on wires haha
It's not the hardest job in the world but worth it when you are finished
