Russ Rallye
		Yeah kind of, ordered a new lever as they call it, they didn't tell me they were handed so they've just assumed and sent me a left hand one instead of a right hand one.Wrong throttle quadrant?
Russ
Thanks mate.Love your attention to detail...I've been following your build for a while and must admit it's my fav on here :up::up:
How comes your using the jenvey throttle linkage instead of the pms linkage ?
Its like driving a different car with the jenvey linkage. You can mash the pedal, or feather it and it works. Plus it always returns. The standard set up from Pure was really hit or miss. And it wasn;t fun going from 100+ to 30 while the car was still trying to accelerate because it had jammed open a bitThanks mate.
Think I've mentioned it already but the linkage is the same setup I've run previously so I know it works fine, the throttle cable is run different to most and didn't want to change that + the Jenvey linkage has a return spring built in where the pure one doesn't.
Russ
Russ, I am curious to know if the slam panel still fouls on the itb's or would it clear as the inlets sweep downwards?
Ta
Of course not! LolAre you going to spill the beans on the power figures ?
Sent from my SM-G955F using Tapatalk
Spoil sport :tongueout:Of course not! Lol
Russ
If all goes well at croft it should hopefully be out on Saturday 7th October at Oulton.Spoil sport :tongueout:
When's it racing ?
I'll get some video for you!Ffs ! I am working that weekend grrr I was also going to 3 sisters on the 8th :tired:
Yes mate it is, Saturday 7th. Not entered yet, but will do shortly. I'll be there regardless as @paulrs4 and a few others are racing even if I'm not.Is it October the 7th your at Oulton @Russ Rallye
I will come up and say hello!
Lovely job as always RussWas going to ask you about the holes left by removing the rubbing strips and whether you sealed them or not. My question has been answered.
Guessing the roof scoop sits over the aerial hole?
lovely garage set-up by the way
No worries mate look forward to seeing you.Looking good Russ, also looking like I won't be working now so hopefully will call in. Is @Tony Hunter going ?
Revolution in Gateshead mate, friend is workshop manager there.Looking great Russ, where did you get Direzzas from I need some new ones unfortunately!
Ha ha. No, not allowed in Tin Tops, roof scoop.
Got to take mine off and refit the headlights before next weekend.Ha ha. No, not allowed in Tin Tops, roof scoop.
Might be worth clearing the bolt hole tapers of paint/powdercoat on those wheels Russ, seen loads come loose because of it.
Impact guns working on that as we speak! Will monitor the situation at croft see how it is, the guy that used to do my wheels always left the face/tapers bare but unfortunately he’s retired now.
