Interior
So, as many of you are aware from previous updates, I'd completely stripped the interior.
However, I had a fair amount of work left to do before I could fit the seats.
First step was to use Gelsol on the remainder of any adhesive inside the car.
Next was to give the interior a vacuum and then a thorough clean after the chemicals used so far.
With this done I was able to get the
@JON FOZ lower seat frames in:up:
The seats as they arrived
Corbeau Clubsports with runners and mounts
Note to all when buying these seats, they don't come with a fitting kit.
That wasn't much of a problem though as I'd bought nuts and bolts for the FOZ Frames.
So with the the interior all tidied I got really itchy feet for fitting the steering wheel
OMP Targa 330mm Suede :smile:
I then got the seats mounted in place...
Admittedly I did this prematurely.
However, I was too excited to see how it all felt to sit in the seats, so did it anyway.
Once mounted I quickly realised that something was wrong.
When I'd sat in the car, I felt like I was sat too far to the right and not central to the steering wheel.
I posted a message in the
@JON FOZ group buy thread and the man himself quickly had a reply for me.
He was also very helpful with suggestions but it was my own fault,
I hadn't adjusted the seat on its Corbeau frames!
Once I'd moved the drivers seat over as far as it would go, I was sat in a much better position.
Once the seats were in and I was happy with their positions, I moved onto the harnesses.
The harness eye bolts that came with the harnesses did not fit in all of the pre-existing seatbelt anchor points,
So I had to source a few more.
The eagle eyed amongst you will realise that the gold bolts are the same as the ones supplied with the harnesses.
I'd had no idea what size & thread the bolts I already had with the harnesses were,
plus I only needed one bolt & plate and another 2 bolts, one for each B pillar.
Anyway, so after I'd worked out what size all the bolts were and what their thread type was, I got the the fitting part
I got the drill out and drilled a minute hole where I wanted the centre harness Bolt to sit.
I then put a light over the hole so that I could place where it was underneath the car.
As it happens, I'd nailed exactly where I'd wanted the hole to go...
More on this below..
This is why I was premature on my harness and seat installation!
Bloody shards of metal everywhere!
I mean, what did I expect whilst drilling metal!
So, I drilled the hole to size and dropped the bolt through.
I then went underneath the car and had to remove a section of heat shield from over the exhaust.
Once that was out of the way it was easy enough to fit the strengthening plate.
A little fiddly, but I put a socket and extension onto the plate and spun it.
Making sure to stay straight and level with the bolt, it caught on and spun its way home!
Lucky me really as I thought it would be a two man job!
The reason I wanted the plate to sit in this location...
Quite literally because it WOULDN'T foul on anything here.
Everywhere else in the centre console was either inaccessible or something would foul.
The cable you see is the handbrake cable and it WILL NOT foul.
The picture below shows where the plate was going to sit once tight,
but this was taken before the bolt was in (obviously) :laughing:
Passenger seat all in!
This side sits lower due to not having rails fitted
It's also sat quite far back, meaning that I'll be able to have a good peripheral view.
And to finish off his update, how about an attractive photo of me
Thanks for reading all
Any questions and/or queries please get in touch
Critics welcomed
20vKarlos
