This past week has been rather hectic in the workshop. After last week's success at startup I had a few days to try and iron out a few issues ready for the rolling road on Thursday.
A good part of this time was spent throwing together the bodywork just so I could transport it to Essex around the M25 while keeping the engine dry from the inevitable rain. The front of the car is still slightly twisted from a rather heavy excursion into the tyre wall at Cadwell a couple of years ago so the old bonnet doesn't really fit properly and even fitting it all playes havoc with my OCD! But with a new shell ready to be built it really isn't worth worrying about it, or spending too much time trying to straighten it.
While fitting the bumper back together I did spend a bit of time drilling a bit more ventilation into the lower grill to help cooling the the oil cooler.
Every little helps!
I still have a few electrical niggles that are going to need attention. I haven't had a chance to investigate why the EPAS isn't working yet but this is high on the list to be sorted before we can start testing. But since fitting some new headlights I have also discovered I have no power to the front lights at all which is odd. No headlights, sidelights or indicators. Every other light on the car is working so I'm just going to have to trace the wiring back. I suspect the white connector in the engine fuse box may be the culprit assuming they run into this.
A small coolant leak was cured easily. (Just needed to fit a jubilee clip. Whoops!) But I've also now got a small gearbox leak from the drivers side driveshaft which I didn't have before. I wasn't too concerned with fixing this before Thursday though. So other than a quick spanner check, wheel torque up and some air in the tyres it was on to the trailer. Which appears to have shrunk!
Anyway, Thursday was a day of highs and lows and ultimately turned into rather a long day.
I was due to arrive at Road n Track at 11am which I duly did. After a quick push off the trailer, (still no reverse) and the obligatory cup of tea I drove the car on to the rollers.
...and 3 hours later I was still there as they built a stable map for the engine. By the end of this they were very happy with the engine which was appearing to be strong, with the only adjustments being a slight increase in fuel pressure and a change to the spark plugs up to a 7 temp rating from a 6 which is standard. (apparently)
Only as they started the power runs did the problems begin and the day on the dyno came to an abrupt end.
Sadly there is an oil leak from most likely, the main crank seal at the gearbox end. The bell housing had filled with oil and of course covered the clutch which was then slipping too much to allow any power runs.
A very disappointing end to the visit as well as frustrating as the bottom end was the only part of the engine that I haven't put together myself. Not that I would have done a better job of course. Being where the main investment in this engine has gone I was more than happy to leave this to an expert and to be honest this could have been a far worse result, so I'm not overly disappointed as it's a relatively straight forward fix even though it means the gearbox will need to come out and I will now have to order a new Helix 4 puck clutch.
So after loading her back on to the trailer I then dropped the car off to Mark Fish as it's going to be far easier to fix this on a ramp and I wanted him to corner weight the car and set up the geometry anyway.
Being the solid chap that Mark is, he is going to speak to the company who assembled the bottom end and suggest they take responsibility for this failure. It is a company that he recommended to me anyway and he has a good relationship with them. Hopefully they'll be reasonable and this fix will not cost me too much.
the main thing though is now to decide whether to pull out all the stops and try and get the car ready for Silverstone on the 6th May, with a test day on the 4th. Or wait until Oulton on the 2nd June.
With an empty workshop I've got a quiet weekend to think about it.
