Austin-182
Another update to make of more diy work on the car, and another problem during the work...
First of all, the exhaust needed attention. All of the rubbers had perished causing it to rattle and start to melt the exhaust trims. I also wanted the decat off because im getting old and the droning noise is no longer cool to my ears.
I went back to AAS who have replaced all mounts, welded a small crack on the original cat from when it was on coilovers and scraped along the floor, and re fitted for me with a new genuine fitting kit.
Next up was 4 brand new genuine injectors and fuel rail. Mine were swapped ages ago when diagnosing a missfire, which didnt turn out to be the injectors but i was left with a 2nd hand old set. I was also told at a later date when it was plugged in that there was a slight missfire onnone of them so they have been on the list to change for a while now.
When starting the car, the fuel line popped off and sprayed petrol everywhere! I realised one of the o-ring seals had snapped!
I managed to find a pack of seals in screwfix and one of them was the same size. Job done, car running again.
I need to replace the fuel rail gaurd which i now have ready to go on.
I also need the engine mounts replacing as the exhaust place said there was more movement than there should be and i could do with replacing them.
