Jekyll
Thanks for the heads up guys. I'll get some from euros then. Might 2ait till they do a deal to save a little extra.
Give the studs a light going over with ACF50 mate, that's what i do with mine to stop them going crusty.
The black self coloured steel goes bad very quickly.
Mine have been in a year now and they still look near new.
Even if the metal is treated (coated) by threading it a couple of times, the metal will have some points without treatment and by having them a little longer, dust and sand from road will cause bare metal spots and rust will appears.
I wish my main worries about my car were surface rusted wheel bolts haha
Not the fact that the gearbox crunches more than a box of Shreddies being bodyslammed![]()
ACF50 and an old small detailing brush dude. If you’ve not used it before, it’s like a medium viscosity purple oil. I find it easiest to spray a little on a brush and brush it on.
gives you more control with it.
Id be tempted to take the A1T items once off to have them zinc coated or black passivated.
That is surprising mate!
Which one are you using, the aerosol version or the bottle type?
I put it on all the threads apart from the shank area that will be loctited into the hub.
I did pre treat mine a few days before i fitted them.
I'll take a pic of what my PMS ones look like later, they've been on a year now and not an ounce of rust.
You’ll probably find that if you’re using a wheel cleaning product such as billberry or similar, that will be stripping the protection from the ends of the studs. So they may need a little spray after every wheel wash.
I havent used it mate, I've not even bought it. That's why i was asking as I'll buy it and do it when my new studs turn up
Would appreciate a picture also, just to ease my mind.
daily car......go back to bolts imo ;-)
@JamesBryan is the bottle too much? Seems a lot to use on just studs or does it not go far?
Race parts on a daily. Saying that, my wheels are off more times than a race car anyway!![]()
That's the spiritAh sod it, I'll just buy it and then I've got it!!
#tryingtobeatightarse!
Maybe time to race it then.... see you at Mallory yeah?
Yeah that's exactly what I mean, a coating of some sort rather than just oiling itIf painting or what ever else surly there is always going to be metal on metal so therefor it would come off so painting is just a stupid idea.
You would be best to strip them back and have them Zinc plated in black or Clear (Silver)
Forgive me if it's a stupid question but something like that surely you'd want to just have it sprayed black to protect it from rust not coat it with oil to prevent it rusting? It's like having your car not painted and just coating it in oil every week to stop it from rusting?
My point was more of a permanent coating as such rather than oiling it periodically. Doesn't matter if its sprayed black, powder coated black, passivated, galvanised. My example was just a suggestionUnder the impression you suggested to spray paint it black with paint.
Problem is you'll damage it everytime you're taking the wheels offMy point was more of a permanent coating as such rather than oiling it periodically. Doesn't matter if its sprayed black, powder coated black, passivated, galvanised. My example was just a suggestion![]()
No reason zinc plating wont work. Risk of hydrogen embrittlement but you still get bolts that are 12.9 and plated. Wonder if theres more risk it being after the fact?It's an interesting point dan. I'm a tad unsure here myself so ask away as I'm sure someone will clarify what's best.
Look identical to mine!Here's what mine looks like.
These have only been done with ACF once since they were fitted a year ago.
White stuff is road salt.
Nice! Thanks for that James.
My replacement studs turned up today so I'll fit them Friday after work. The ACF50 should be here tomorrow so I'll give them a few coats, prior to fitting.
I ordered 10 of each, so I've a few spares of each size.
