Speedo Gonzales
Yeah I think it's been moved too!Looking at pics 2,3 and 5 it seems like somethings moved/moving to where they have originally been bolted tight
God knows mate!Why would the steering column have been moved??
Yeah, those are the bolts.
Re centralize the column (ie, shake it around until you’re on those markings again), and torque everything up.
To do a nice job here’s the tightening sequence, 20nm on the bolts.
Rip the steering surround off, flathead behind the audio control stalk to pop it off and 3 torx screws sandwich bottom and top together. With that off you should see all the bolts you need to access.
Better to not loosen the steering column adjuster (I did it with it loose but this is what the manual recommends)
Yes it will stink of diesel fumes. Should be able to find out what cylinder is leaking when the engine is idling, or as @YorkshireKyle said the black gunk.Car absolutely stinks of exhaust emissions if that might be any indicator as to what the loud ticking noise is?
Would the injector seals cause a strong smell of emissions? @Brigsy
Shine a torch down the side of the injector and look for any black gunk
f**k knows why he didnt replace the fire seals anyway the spastic t**t. They're about £5 ffs
As above the injector seals are pennies, should be replaced and seats cleaned up in the head, and injector clamps torqued up properly, or they fail.
Its not ideal but should be able to drive it steady, check the clamps are still on the injectors just incaseCheers Brigsy! Makes me a bit less worried now. Wont have caused an issue to the injector if it is that will it? And would you say I'm safe to drive back down boro from mine like that?
Leave a negative google review. They dont like it when you do thatSorry to hear about all your problems @Austin-182
Renparts are absolutely flipping useless mate, I fully understand your issues as I’m having the same with them at the moment!
I still cant het over the service I had from them. The lady who I spoke to throughout was unbelievable a real life blagger, excuse after excuse and quite simply a liar even when presented with evidence.
Sorry to hear you are having the same problems, I really hope you get it sorted.
My refund had been done but it takes 28 days to go back on your card apparently. It took an abrupt call in the end which isn't how I like to deal with things and funny enough the payment magically went straight into my bank.
I’m hoping not to have to go that far but may have toLeave a negative google review. They dont like it when you do that
My part is only a £90 meggy hub but is now into the 3rd week of waiting and I want to get my meggy finished off whilst I am furloughed. Yes this is the problem she just comes out with so much cr@p that she trips herself up and can’t remember what she has said. I have said just be honest and say you don’t have the part and I will find another, but says it has definitely been sent but can’t provide a tracking number as it’s internal delivery?I still cant het over the service I had from them. The lady who I spoke to throughout was unbelievable a real life blagger, excuse after excuse and quite simply a liar even when presented with evidence
For me, i was told engine would be delivered in 3 days max. I rang a week later after Kris asked me where the engine was and I had assumed he already had it. When i rang she said it had been sent and she would chase up with the courier and would let me know. She never ever called back and I had to keep ringing for the update. I was told it would be delivered tomorrow and 5 days later still no engine. In the end, I rang the courier company who provided me with a copy of the details of when Renparts placed the order for the engine delivery, which was 3 days after i had rang to initially chase up where it was. And this was all before i even had to deal with the issue of missing injectors and faulty pump! Never ever again!
I have since heard that they often sell parts they do t even have and then try to either source them elsewhere or even buy a whole car for the part. Would explain why the delivery takes so long and you get excuse after excuse.
Im still waiting for the email and letter in the post for the invoice I have asked for 4 times.
Bit late to the party now but mine had a similar issue and it was a tiny pin prick hole in the fuel line letting air into the system.
