A tiny little upto,over the easter weekend i decide to take all the scuttle panel off to do the trim restore using Gtechniq C4 & other trim parts.
I first gave all the trim parts a clean with Hot Water,Fairy Liquid & Multi Purpose cleaner.Lucky were having great weather as all parts dried off in no time,once all dry i wiped down with IPA a few times then begun starting to apply the C4.This was pretty easy to do & i also bought a small box of lint free pads as you only get a couple in the C4 box.Left the panels to dry off over a couple of nights indoors then refitted.
While i was at it i also took my filter off for a clean & re oil.I will be ordering some black Silicone hoses for the induction,as at the moment i have blue & want black to go with the car,as i will also be painting the inlets etc soon.
On others bits i have replaced the upper gearbox mount & got a set of stainless button head bolts to replace the rivets on the lower skirts.
I also got a pair of solid top mounts coming soon thanks to
@Dr Jekyll
Thinking of also getting the Roll Centre & Bump Steer kit also 😁
