Clio 182 Turbo
Busy again today. Seems like 1 step forward and 2 back some days 🤦‍♂️. Front end off again. I’d got all but one of the sump bolts out. One rounded going back in so knew it was going to be a ball ache should it ever have to come off again. It didn’t disappoint lol
Got that drilled out fairly quickly and the sump off. Turns out I’d just done a shite job of the return. No idea how/why but the whole lot was only finger tight. I’ve tightened it all up and put new seals in and filled the sump with old oil to leak test it. I’ll leave it overnight and see how that goes. Photo of said sump below:
Then last up was my other schoolboy error... put the brembos on the right way round and bled them again. Had a little splutter of air and the pedal is now rock hard. Seems to have done the trick so well happy with that. Thanks for the help on that one 😊
last question for today... are the sump bolts M7? They are total shite and no doubt it’ll have to come off again so I’d prefer to use some normal bolts rather than the E8s. Plus they are 3 quid each which blows my mind. Can anyone confirm the size or have a link where I can get some alternatives?
They are M7 bolts. You can find on ebay some titanium ones with "normal" hexagonal head. But I cannot anymore find them.
I use anti seize on them and torque to 17nm at most
Made a little bit of progress today but not much. I’m waiting on my new sump bolts so anything engine related is out of the question. Instead, I pinged a door bullet off to get that sorted as they are in an awful state. Used a hacksaw and file to get the letters off then built it up with filler primer. Looks like it’ll flat off ok.
I’ve got some stickers ordered and hoping the end result will be something like this.
Next in line was the boost gauge. Whipped the dash top off
Popped the drivers side vent out and put the 3D printed slats in
Then fitted the gauge. Just need to find somewhere to bring the boost feed through then I can get the dash top back on
I’ve also done a leak test on oil return v2 and all seems well so far so happy with that 👌
The sump went back on today, all be it just pinned in with 2 original bolts while waiting for the new ones to arrive. I just needed to get the engine back on its mounts and in place. I measured up the 172 decat and chopped a bit off
lined it up and seems like it’ll be just the job. I’ll chop the 182 decat to match and pop a sleeve over them. That should get me running for now. I’ve got literally no idea how I’ll get to the bolts between the downpipe and the exhaust. I’ve lost the gasket so need to order a new one for starters. Should they be spring bolts or are normal ones ok? Also it would appear the wife thinks she’s funny and drawn a willy on there too 😂
I’m still waiting for parts so didn’t manage much today. I did have a few random bits kicking about though. I fitted my rear wiper delete which I’m actually really impressed with and stuck on the rear plate I’ve had kicking about for ages. The exhaust is off one of the hangers in the pic, it sits perfect when it’s on
My exhaust fittings arrived today so got cracking. Started off by heat wrapping the adapted 172 decat
Then got it lined up and tightened. What an absolute ball ache of a job it was to get the bolts and springs all on. Not sure what awkward french bloke came up with the design but if the threads were literally 5mm longer or the flange an inch or so in each direction it would be so much easier. After much swearing I finally got them on. Then getting anything on to tighten them was another challenge. Got there in the end and they seem tight enough but I’m sure I’ll find out when I start it. It’s now sat nicely in place. Just need to chop the 182 down to match and then stick the sleeve over and jobs a gudn
Today I dropped what was left of the box oil and refilled with some new fluid. No chunks of metal came out in the old fluid which was a massive bonus.
I’d refitted the sump last week so went round and checked all the bolts were correctly torqued which they were, then put the oil return back onto the turbo. I also changed the routing of one of the coolant lines slightly as it was running very close to the downpipe.
Next in line was the exhaust. I chopped the 182 decat to the right length and put the sleeve over. Looks like a massive bodge but it’ll do till it gets welded properly. I’ve knocked it off the back hangers when sawing it so need to sort that once I get the front end back down.
Last bit for today was rebuilding. Got all the boost pipes back on and lined up, the ecu back in place and plugged in. Then refitted the slam panel and front bumper. All the fluids are now in so gonna leave it up in the air tonight and check for leaks in the morning. Hopefully all is well. This is where it was left to tonight... the end is very close
Today I finished off all the little bits left to do. There were no leaks or drips overnight from anywhere so looks like oil return round 2 is all good. I refitted my arch liners which really are in great condition and got the car back down on all 4. I then did a nut and bolt check to make sure everything was tight which it was. Jumped in ready to fire it up and..... can’t find the f**king key. God knows where it’s gone. Turned the garage upside down and can’t see it anywhere 🤦‍♂️😂😂. So, here’s how it sits for tonight. Happy new year everyone, I hope 2021 brings me a key (or even the spare) 😂😂
Hopefully much more to come in 2021 including getting the garage skimmed and a new floor down 👌
Found the key!!
got it out onto the drive so I could properly open both doors to get the dash top back on. Ran the line for the boost gauge through the grommet under the pas bottle. Doesn’t look too bad I suppose
I then gave it a quick wash and it came up brilliantly. The front bumper is a bit stone chipped and could do with some paint at some point but aside from that it’s pretty good
and the brakes look massive under the wheels 😊
The exhaust needs some TLC as I’ve knocked it off the back hangers. Tried to sort that today but snapped my 1/4” to 3/8” adapter trying to take the mounts off so that stopped that fun. A cable tie did the job well enough for now.
I ran it up to temp and left it for a bit. Got some Smokey fun from the heat wrap but all seems ok. The brakes seem a bit spongy still so I’ll have to see what it’s like when it’s driving properly. I’ve got a fault code for the lambda sensor pulling in so need to check that out. Originally it was unplugged but now it’s in it’s still there so that’s next up to sort. Vid of it running and throwing heat wrap smoke everywhere
Looks good Steve and following with interest as I'm heading down the same route!
Regarding your fuel rail......I looked at a phase 1 rail and the part number is the same as a 2003 2.0 Laguna.
Just wondering if this is a possibility instead of trying to track down a rail from a phase 1?
cheers, good luck with it!
you can make a ph2 rail into a ph1 one. They are the same aside from the hole to allow the fuel to the fpr. You can just drill that into a ph2 one and good to go
Had a free afternoon again today so finished a few bits off. Started by swapping the lambda sensors. Old one looked a bit shitty to be fair
next up was getting the exhaust back on its hangers. Mid section went on fine, then it was the turn of the back box. Underneath is pretty decent and even the heat shields are ok. Rear beam needs a lick of paint at some point though
The tail pipes came up really well with a quick wipe down. I’ll clean them up properly with the drill polisher when I get a chance
I’m really pleased with how it’s all lined up this time. It’s better than it was sat originally and about as close to perfect as it’ll ever go with the Renault hangers
I eventually got round to firing the car up today after sticking the battery on charge. I’ve still got codes P0130 and P0135 which are both codes for the front lambda sensor. I had the codes originally so I’ve swapped it for a new on, then when that didn’t clear it swapped the front and back and still the same. I’ve made a new thread for it if anyone has any suggestions for anything else it could be or anything else to try P0130 and P0135
A quick read up shows these as likely causes:
  • Faulty Pre-Catalyst oxygen sensor
  • Faulty wiring/connections
  • Short or open ground in the wiring
  • Blown Fuse
  • Engine coolant temperature sensor is not operating correctly
  • Faulty Power Control Module
You fitted new Bosch’s lambdas?
Well, 1x new Bosch lambda. Just replaced the front as that’s the one with the code.
  • Blown Fuse
I’ll have a check of the wiring and make sure it’s all ok. When I ran the car without it plugged in when I fired it up with just the downpipe on it was rough as sticks and has improved with the lambda in so it’s def doing something. Coolant sensor is new so don’t think it’s that but again I’ll check it out
Have you checked the earth wire at the back of the gearbox, think it is on the same section of loom as the lambda wiring.
It seemed fine when had a look. I’ll give it all a good clean up and make sure though 👍
Today I bought ANOTHER genuine Bosch lambda sensor and returned the first one I got. This one was slightly different and had the clip that sits in the subframe so I’m not sure just how genuine the original was.
Anyway, the codes are now gone and all is well in the world. I’ve still got a bit of hesitation when first reviving but to be fair it just needs a good old run out to sort it now. The lambda graph with the new sensor is below:
The last job for today was to sort the bonnet catch. No pics but removed it and the latch was totally caked in s**t and jammed open. Cleaned it up, greased it then smothered it in copper grease and my bonnet now shuts and stays there for the first time in 2 years!
Took the car for a little drive today on my personal test track that is in no way the same or similar to the A1231. Findings are interesting... brakes are shite initially but work well under proper pedal pressure. I managed to get the abs to trigger so I’ll try bleeding again and hopefully that’ll clear the last of the air. It’s also really quite quick but I have ALL the boost. I let it run up to temp and pottered round for a bit under mild throttle and the first attempt at full throttle it spiked at 25psi 😂😂😂. It really did go very very well but decided it was probably best not to try it again. I have a feeling the actuator may need adjusted slightly haha!
Did a bit of you tubing on churbos......the waste gates themselves aren't as big as the Garretts they're based on and it looks like its a common mod to drill them out.
Obvs, with a smaller wastegste the actuator are has to open the flapper more the control the boost.
Worth a look at some of the YouTube vids on chinese turbo wategate porting
yeah I saw some vids on that. I’m reasonably sure it’s the actuator though. I had it off and had to modify the bracket so it didn’t hit the bulkhead and just guesstimated with the rod length. I’ll wind it in a bit and try again and hopefully all will be fine
Little rocket! :ROFLMAO: I bet it's a great feeling driving it knowing you've turbo'd it yourself!
yeah it was great. After a few years of driving big German things it was actually really nice just to be back behind the wheel of something little too. Also It’s insured but still lacks in mot and is sorn so the experience was slightly spoiled by making sure no policeman officers were on my private test track at the same time 🤣🤣🤣
25psi!!! Christ, are you eventually going to run boost control?
Yeah, going for manual boost control so more boost = more throttle and less boost = less throttle 😂
In seriousness no, not at the min. Once I get the actuator right it’ll be fine for low boost. If I go high boost at some point I’ll get a boost controller of some flavour
After yesterday’s escapades with all the boost, I adjusted the actuator arm and went for another test drive. I was on a different personal private track tonight which bore no resemblance in any way to the a195.
Anyway, I now don’t have all the boost, I have NO boost 🤣🤦‍♂️. Spikes at about 3psi. Clearly I’ve now gone too far the other way. Was far too hot to change tonight so I’ll try again tomorrow. Third time lucky hopefully 😂
Not much in the way of Clio updates, it’s been raining and it’s scared of the wet so stayed hidden in the garage. I did however, go to Greggs for a bacon sarnie this morning and the dad wagon looked pretty damn good in front of the sunrise
Finally got the boost right today. May still be a bit too high but one turn or so should do it. It’s spiking to 10psi and holding 8 so only just too high.
Verdict..... What an absolute laugh it is. The car is a total waste of time. The roads were a bit greasy and damp from the frost last night and it was happily spinning in 4th 😂. When it does eventually get grip or find some dry tarmac, I was really surprised at how fast it actually is. Obviously being french, rattly and noisy adds to it, but it seems really quite quick. I quickly managed to get the rust off the rear brakes and burn the crap that coats the new front disks with a few heavy braking attempts and the brembos feel fantastic.
Overall I’m really, really pleased with it. It still idles like a sack of s**t, especially when cold so maybe some investigation to do there but there’s no lights or fault codes so it can’t be too unhappy about it.
It certainly turned a few heads of the local dog walkers when it chattering and popping and banging when I was out in it 😂. It’s booked in for a MOT next week so once that’s done I can take it out and properly enjoy it. Got a feeling unless the roads are bone dry it’s gonna be a bit pointless though 🤣
This is exactly what I wanted to hear!! I don't need much now to start my build 😁
Please excuse the exhaust blowing it’s tits off, I’ve ordered the wrong size sleeve to join the 172 and 182 sections. That’ll be sorted this weekend.
Ive got some idle issues as you’ll hear in the vid below. It’s worse when cold like it is in the vid, but even when hot it seems flat and hunts all over at idle and when the revs drop it’ll cut out from time to time. Under load and at any normal revs it’s perfect and feels totally fine. There’s no lights and no fault codes either. Injectors, lambda, and map sensor are all brand new genuine parts and very recently fitted. The leads, plugs and coil pack are less new and were fitted around 18 months ago but have literally never been used with the car not having moved. They are genuine too. It was doing this prior to the turbo too, so it’s not something new. Not sure what else it could be, any ideas?
Still got idle issues but som stickers turned up today which made me very happy. They may not be to everyone’s taste but I like them. Massive improvement over the thoroughly terrible condition the bullets were in
I spotted when I was on the treadmill mid week that the Clio had picked up quite a bit of salt last weekend so decided to drag it out for a wash today. I’d fitted my new exhaust sleeve last night which has all but cured the blowing but all the pushing and pulling has moved the exhaust on the hangers slightly. I’m gutted because it was sat perfectly. Anyway, got to say it looks pretty good out there in the winter sun. There’s a few marks from where it’s been garaged but on the most part the paint work is immaculate. Considering it’s never seen wax since 2017 and only been washed a handful of time since it’s not bad at all! It’s booked in for a full correction including making the headlights clear again in April so it should look fantastic when that’s done. I also properly fitted my head unit with the correct cage as it kept dropping out and taking chunks out of my knuckles last weekend too
The misfire saga continues. I ordered some new plugs and leads which turned up today so got them fitted. Total pain in the arse having to split the inlet every time you want to do anything.
I checked the gaps on the new plugs which were all spot on as expected. The old plugs looked a bit worse for wear. Amazing how bad they are considering they’ve barely been used!
Got it all back together. I’ve also got a battery cover arriving this week which should help tidy the bay up a bit
fired it up and it’s still exactly as it was! This is the issue that took the thing off the road in the first place! It’s changed as parts have changed but still there. It’s fine under load up the rev range but low down it totally flat. The vid below shows what it’s like when revving. The only other thing left to change is another coil pack but that was brand new and covered no miles too! Is there anything else obvious I could be missing?
