Our new ph1 172
172PH1
  Ph1 172
Genuine fuel pipe arrived yesterday from Renault
Fitting it in the morning and hopefully my mate has started cutting out all the rot
172PH1
  Ph1 172
New sill repair panels arrived this week. So made a start cutting out the outer sill.
The plan is to weld It below where the top of the side skirts are.
Next step remove the interior and get the inner sills made up and welded in place
172PH1
  Ph1 172
So I've welded the outer sill on the ns, inner sill and the mid sill to make it super strong.
The os sill is also welded in place
I've only ever welded once before so I'm happy with how it's turned out so far
I'll be drilling a couple of drain holes along the outer to help stop the issue again
Next job is to grind the welds back, prime them and add some protection and then underseal the car
172PH1
  Ph1 172
So we picked the car up from the garage on Saturday. I'm so glad it could be saved and put back on the road in a safe condition
Inner and outer sills welded on both sides, protected and now under sealed
Also fitted a ktec panel filter as I didn't want to loose the Oem look under the bonnet with the ph1 airbox
Cup spoiler fitted
Private plate fitted
And took it out for a drive 👍🏼👍🏼
172PH1
  Ph1 172
Noticed that the drivers reverse light wasn't working last night so removed the light to investigate
Some people's efforts are terrible🤦🏻‍♂️
  RS6+ & 40d MSport X5
Well played mate. Starting to look like a cracking little Ph1. Keep up the good work. 👌🏻
172PH1
  Ph1 172
Well played mate. Starting to look like a cracking little Ph1. Keep up the good work. [emoji1305]
It's a long way off how we want it but it's getting there
Sent from my VOG-L29 using Tapatalk
  Edition 30
Absolutely love this. Silver door strips and clear side repeaters and it'd be perfect.
I even like the wheels!
172PH1
  Ph1 172
I have to admit I do prefer the black trims on the ph1
I'm also contemplating a set of the ph1 rear lights
172PH1
  Ph1 172
Gave the car a service in work today, and fitted the outer temp sensor as it was suffering from the standard sensor issue...... 34 degrees outside apparently 🤦🏻‍♂️🤦🏻‍♂️
Full service with genuine parts
Oil
Oil filter
Fuel filter
Plugs
Sump plug and washer
Genuine inlet manifold gasket and o ring
Sorted the door rattle on the passenger door
KitsonRis
What was the issue and how did you fix? My drivers door card is rattle/vibrating only on idle about 90% of the time and putting my knee against it stops it. Looks like all the clips and fixings are being used but the door cards were off recently to fix the windows and must not have gone back on perfect. I am sort of reluctant to take it apart in case I make it worse as removing panels like that I have always found never go back perfect.
172PH1
  Ph1 172
The bracket that the silver grab handle screws to was rattling. I put. A bit of anti rattle tape behind it and that sorted it
KitsonRis
Ours used to stop when I pressed my knee against it. Luckily it was an easy find
Oh really? I would not have thought it was that. I can see the whole bulged aread where the arm rest is moving and pressure above the speaker grill stops it. If that is the case then I might risk taking it off.
172PH1
  Ph1 172
Decided to investigate why the high level brake light wasn't working
Removed the spoiler to find a corroded connector
Stripped the wires to find them rotten
Removed the light unit last night and tested in work today the light unit itself is fine just need to make a new loom
Led unit plug stripped and new wires and pins sorted. Jobs a good en 👍🏼
172PH1
  Ph1 172
Center led isn't as bright as it should be unfortunately.
Does anyone know if there are any replacement led stips available that would fit as a replacement?
172PH1
  Ph1 172
Replacement led strip sourced and fitted. Also fitted the ph1 rear lights
In my opinion it looks better
172PH1
  Ph1 172
Bit of an update
New inner steering arms and track rod ends fitted ready for the rs peak district drive next weekend
172PH1
  Ph1 172
Fitted a new number plate light as the old one was tired
Makes such a difference to the rear
172PH1
  Ph1 172
Went o the rs social drive round the peaks on Sunday
The 1st proper drive of how they should be driven...... And it didn't disappoint.
Surprised a few people of how it picks up and holds the road to be fair
Couldn't stop smiling the whole day
172PH1
  Ph1 172
The clio hasn't really been used since the rs drive, its just been sat in the garage.
However mot this coming weekend and new front abs ring then to start using it for a bit
172PH1
  Ph1 172
Replaced the old snapped abs ring at weekend due to the ring causing the standard abs feel under breaking
172PH1
  Ph1 172
Replaced the shocking crappy 25w pioneer speakers all round with some upgraded vibe speakers
