Questions about RS tuner
R3k1355
Absolute wetter.
Still got an intermittent throttle pedal issue which I need to sort, it goes away if I unplug and plug back in the pedal so it must be a connection thing but I can find it.
There's a common issue with the contact tracks on the pedal sensor isn't there?
Tried removal and cleaning with isopropyl alcohol?
DomP182
  ph1 172, Arctic182
Do you mean inside the pedal itself rather than the plugs?
R3k1355
Absolute wetter.
I never bothered to do mine, got a couple of error codes but it still worked fine.
Few people on here have dug deeper tho, so worth searching around.
Ross_clio172
  Clio 172
I also got send this after I ordered the chip thing is a do quite often do short journeys were the engine won’t get to full temp do you think it might be a problem ?
Ross_clio172
  Clio 172
So it’s more of a general thing then rather than saying it’s going to definitely do damage ?
