The last update for 2021! I've had the car back just over a year now and its gone through a huge amount of changes even though visually you wouldn't know it. Its basically a completely different car. Quite the project when you look back at it but its been really fun to build, it has saved my sanity during Covid and given me something to focus on
Anyway on the last day of the year I managed to sneak in a cheeky turbo swap. I've got a lot going on next week and am in for an operation on my guts and after that mobility and having the ability to work on the car will be very limited so I decided to do this now and get it booked in with EFI when they open back up. There's a possibility even driving is possibly going to be off the cards for 6 weeks. I've decided to just "send it" for now and aim for the magical 300bhp. The turbo should actually be good for a chunk more so will be ok on the next engine if I build one. I still have the fuel rail to fit when my fuel hoses turn up but that should be an easy job to do. The swap itself was very easy,
@Brigsy pointed me in the direction of doing a cold side swap which was a really good shout as not only does it make the job easier my "new" rear housing was badly cracked so a win there. No need to go through the process too in depth, undo some bits, remove the chra clamp to the rear housing and wiggle out the core and front housing, replace it all with the new bigger 19T compressor and chra, prime it all then fire it up, jobs a good un
I also modified the heat shield/water feed, I don't use this on my car but it form part of a nice heat shield on the right of the engine. All back in, awaiting the Cooksport fuel rail to be fitted then off to EFI hopefully at the end of Jan/start of Feb.
Thanks for reading and Happy new year to you all
