Cheers gents, can have a chilled day tomorrow. No car stuff🤣
Haircut, Wetherspoons for dinner and might have a w**k
Treat yourself to a royal w**kCheers gents, can have a chilled day tomorrow. No car stuff🤣
Good soupw**k in the bath, sieve it out for ar lass incase she wants to wash her hair
It would have fucked my brain seeing 3 on 4 and 4 on 3Next time you do that (there will be a next time cos of who you are) just swap them on the coil pack end if there's enough length left!
I'll be sure to check that mate, if it's that then happy days👍It’s a long shot, but check the plunger for reverse gear. It’s the 16mm socket sized but that the return to centre spring sits on.
I’ve seen them leak around the base, and because of where they are, you’d swear it’s the selector seal.
Like I say, long shot, but you don’t have to pull the box if it’s that.
Aye loads better since last time, no more 1 tyre fire and the car is so predictable with the roll centre kit. Still needs something more to keep up with the lighter cars out of the cornersLooked like it was going well mate![]()
Aye I had so many people down for passenger rides but tie literally passed so quick it was unreal. When I've got it fixed I'll book on at Croft and we'll have a f**k about Jon👍The roll correction kit makes a massive difference. The trophy feels the same on the Northloop kit, absolutely planted and solid compared to stock setup. I wanted a run out in yours as passenger but time just flew by, next time![]()
Did you get ethan round to jizz on them hoses? @leeds2592More CSF pics. There's about 40 in total so just added a few of my favourites
View attachment 1605477View attachment 1605478View attachment 1605479View attachment 1605480View attachment 1605481View attachment 1605482View attachment 1605483
Since CSF there's been a slight leak on the cooling side (alongside the dribbly gearbox), the new hoses needed a heat cycle and the clamps had loosened slightly so needed a quick nip up.
Rotated my airbox slightly too so that both trumpets are fully into the opening for fresh air
Nah I didn't get invited to that party mate 😥Did you get ethan round to jizz on them hoses? @leeds2592
I don't f**k about when it comes to a brewProper builders brew that, ooft.
One of them deffo needs a rectifier which are about £75 on their own if you can find one😭Still working from home tomorrow then?
Worth pulling your other alternator apart and figuring out whats up.
Yeah the brushes and bearings are a piece of piss to get hold of mate. There is another Valeo model very very similar but uses a single wire exciter on a post instead of a 2 pin connectorWonder if the a diode pack off another similar alternator would fit? The brushes and bearings look pretty basic/common.
Sounds bodgable to me!Yeah the brushes and bearings are a piece of piss to get hold of mate. There is another Valeo model very very similar but uses a single wire exciter on a post instead of a 2 pin connector
This is a 75A cup alternator mateMind sharing where you found an alternator for £172? Likely going to have to replace mine shortly assuming it's my whine. Cheapest I could see was about £220.
Jokes aside, second/third links look goodIs it this one Kyle?
Ηλεκτρικά Ανταλλακτικά Αυτοκινήτων - Εξοπλισμός - Autospark - B2B & B2C
Όλα τα ηλεκτρικά ανταλλακτικά αυτοκινήτων και εξοπλισμός συνεργείου σε ένα e-shop. Στην Autospark μπορείτε να βρείτε επώνυμα και εναλλακτικά ηλεκτρικά ανταλλακτικά αυτοκινήτων, φορτηγών, δομικών μηχανημάτων.www.autospark.eu
https://www.amazon.de/dp/B00CVZUYR6/?tag=cliospnet01-21
NEW VALEO OEM ALTERNATOR VOLTAGE REGULATOR 2542638, 593546, 593689, 82-62N | eBay
Valeo 2542638, 593546, 593689, YR1615PF. Valeo 2543552, SG12B009, SG12B050, SG12B089, SG12B095, SG12B103, SG12B108, SG12B110. Valeo New 439663, 2543530, 439661, 440246, 439292, 439292, 439341, 439575, 439479.www.ebay.com
