Call of Duty: Black Ops 6
Adamm.
Anyone elses game keep crashing?
Just the occasional black screen bug and a dev error that kicks me out when loading a game but just back to menu. Are you overclocked though as I heard someone saying even with stress tests it was fine but turning the clock down made it more stable.
YorkshireKyle
Not overclocked but I have a fan profile set. I might drop my game settings down because even with a decent fan profile set my GPU is sat at around 85 degrees
Daz...
  Inferno 182 Cup
Overclocking your GPU has been an issue on these games for a while now. My old one had to be set lower than standard for it to not crash.
So you can use cheats but don’t you dare try to get more FPS.
Daz...
  Inferno 182 Cup
Sounds like it might need repasting.
N0ddie
  Tesla Model 3
Still don't understand how SBMM works on this. Won 2 out of 5 playing with BooBoo (he stopped playing with me as a result) :ROFLMAO: . Later one I played a load with Oli and I think we managed 1 win. Win/loss ratio is now down below 0.70 for me :ROFLMAO:
Score per minute is around 325 with a K/D of around 1.67.
Every game is hard. Seen my first Prestige 4 early afternoon then loads later on.
Adamm.
I was getting around 90-100fps even with DLSS on ended up using icemanisaacs settings and now getting 110-130 without DLSS. Definitely quite an improvement tbf even changed some stuff in the config file which I never usually bother with. That's 4k with a 3080 which isn't too bad imo.
Adamm.
I guess that's considered quite a low score per minute for someone who's probably in the top 10% for k/d. Maybe you're playing the smart strat though some games I'll just go full negative by just throwing myself at the objective like a complete goon.
N0ddie
  Tesla Model 3
I used his settings as well. Looks good still but a significant improvement over the settings I used previously.
Ph1 Tom
No teammates ever play the objective 🙃
Adamm.
God damn this game is sweaty 😂
Adamm.
These sad f***s only run hacks because they are dog water and got sick of getting s**t on without them. Sadly it'll never stop.
I saw something recently about how a load of old accounts from even way back in verdansk got randomly unbanned 😂
N0ddie
  Tesla Model 3
Thursday is Warzone integration day.
interesting to see how they manage/balance the MW guns vs the BO6 guns.
It'll feel significantly different even with just the different movements etc.
Adamm.
Oh, well that’s not the case then 😂😂👍
Recon has been nerfed it used to show enemies for 2 seconds after respawn it now shows them for .5 seconds so a lot less of an issue. You can imagine how 2 seconds was an issue especially on moshpit. But it does still give the heat signature similar to a snapshot after dying.
The broken aspect which people were abusing was in SND you could run mid map etc then select loadout with recon perk and as long as you hadn't shot your gun it would activate the perk and give you all the information but they've completely disabled that aspect of it.
Adamm.
From what I gather the BO6 guns with the current damage profiles none of them would even be near the meta so I think they'll be getting a full rework/new damage profiles specifically for WZ.
It's funny that it's going back to the original Urzikstan though before they put superstore in and changed popov 🥱. At least there's a new resurgence map but until March/April when we get Verdansk BR is going to be boring with nothing new it seems.
Aaron..
I wonder what they will do with Verdansk. If it'll carry on with the fault lines, bunkers etc or if it'll be a different era with a revamped map.
I'd like them to do it like the original map where the dam was still intact and get rid of all of the zip lines etc.
Just looking at the timeline although I'm pretty sure things are missing from it like the bunkers opening, dam bursting etc
March 2022, during season 2 of MW2. Verdansk is launched.
Season 4 they added train tracks.
Season 5 they opened up Stadium.
Then Verdansk 84 which brought Array and the construction element of Stadium as well as Nakatomi plaza.
Cold war season 4. Crash sites added.
CW season 6 they added the destruction and ravine.
Then it went to Caldera.
Adamm.
I wouldn't be surprised if they bring old dam with water and the iced up river will probably be all water now too seen as swimming wasn't a mechanic back then but is now.
Will be interesting though what else they do with the map I imagine it'll have quite a bit of a rework but I'll give it a few months before people get bored.
Then there's the other big map Avalon that I've seen but no one knows when that will release but likely next year's integration also I believe next cod is all B02 maps for multiplayer.
