“Charlotte” The 182 FF
At last some pics and the start of my (probably slow) project thread.
Picked up with limited history but from a friend who’s spent £1400 on lots of new bits like brakes, calipers, clutch, exhaust etc etc only to get a mk3 and sell this one.
I got it at a fair price but it needs some love as you’ll see. My intention is to not modify it but maintain it as stock as possible with some minor mods that I think really benefit the overall car.
I’ve done this before and termed it Stock+.
To first part will be to get and fit the missing bits, like the 182 steering wheel and gear knob, then sort out some odds and sods that are broken as well and deep clean it, as it’s pretty grubby.
Having been over it with my paint depth gauge it’s all original it would seems which is good, there’s some age related marks on the Bodywork that I’ll fix and the interior is, in places disgusting, but more on that to follow.
Here’s some pics to start with,
I'm upset my A pillar was in the way, all you can see from my footage is tyre marks from where you've left the track🤣
To be fair to myself, I was coming into coppice and I heard a noise that sounded like a cable tie had been attached to my driveshaft, by the time I got to Chris curve it was gone. Then the next lap it was back again into coppice so I kept letting off
That and the fact I had a mini moment into hairpin, I'll see if I can get that footage. f**king thing hurt my wanking wrist
Do you reckon it was the rear toe out that caused it or the zero throttle on entry?
Everytime i've been off in the wet it's been down to no/not enough throttle.
It looked like you could have potentially saved that by getting back on the power, but at least it's not too much damage.
Zero throttle on entry almost certainly, i think it was a bit faster than previously in the wet and held off longer getting on the power.
As I sat there I realised I could have probably saved it by flooring it but my lack of recent experience made me reach for the brake... hard to overcome the natural reaction to brake.
Need to have a sticker on the dash to remind me all the time that power will always help :ROFLMAO:
Yeah it's hard to overcome the natural reaction, took me years.
Looks like you did try to blip the throttle but it was past that point then.
One of the reasons i hate wet track days 😂
For next time...
In all seriousness, bad luck and atleast you're fine and the cars not to bad.
For next time...
Funnily enough on the "being fine" I am 100% fine but the only thing my wife said when I got home was "you need a new helmet". Which she is 100% correct about, its my old motorbike helmet and when I say old, I mean a bit to old really, so started looking for a new one.
Taken the offside suspension assembly and the only damage is a bent main pin on the ProAm roll centre kit. Safe to say the updated V4 pins are pretty strong now! Scott is organising me a new one and a replacement pinch bolt as well. So should be all good in a week or two.
Did have to repair the metal work under the bumper as well. 100year old bottle jack to the rescue again.
So all that’s left is to fix the paintwork on the bumper which I think I’ll just do my best with a rattle can as I’m sure it’ll get scuffed again at some point.
Main pin from ProAm sent next day, service was excellent offered to take the whole lot back and check it but it’s obvious what always damaged.
So new main pin fitted and it’s back together, trackings still out a bit but not as bad as before. OEM wheels fitted ready for storage.
Have you checked the tie rod for straightness?
I did - Looks bob on. Going to get the garage to double check it when I take it in for tracking, if its bent then I'll replace it.
Tracking isn't really that far out now either but you can still just see by eye that its not quite where it should be.
Seems like it’s been ages since I updated this thread. The Clio has been in storage since Cadwell, I’ve fixed the bits that I bent and just need tracking up now really.
I’ve been over a few times to do some odds and sods, nothing major just hits like quick release bumper and removing some sound deadening.
I did buy some headlight blanks though as I didn’t want to break a brand new Hella light if I ended up off the track again.
I’m heading over again in a week or so to add some 6 point harness eyelets as I’ve been using a frame that was made up for the under seat points but they mean I have limited flexibility in seat position so I’m taking that out and doing it properly.
Then I’ll be doing the tracking and might take it for an MOT, but essentially making sure it’s right for Cadwell on the 24th Feb.
Those that read this thread I am asking for your thoughts?
I know the current clutch isn't 100%, it slips after about 30mins on track, only a bit 3rd to 4th. I would just swap it out and be done with it but I have plans this year for engine and gearbox mods.
When I do the gear box and engine stuff I will fit a Sachs racing clutch but I am contemplating just throwing a OEM one in for now, I know there are some quality issues with them but its not likely to be that long tbh.
So the way I see it there are 3 options
1. Just send it as is and hope it doesn't give up after 2 laps at Donnington
2. Replace with a cheaper OEM and swap to Sachs racing one when I do the other work
3. Get a Sachs one now and just swap that to the new gearbox when I do the other work?
Thoughts?
Send it... you're going to replace the clutch when you do the engine & gearbox mods anyway.
Would seem pointless, to me, to do a clutch change twice.
Thanks, I was thinking this, my main worry was if the clutch expired it could take the bell housing with it, which would be less than ideal!
Option 3.
Option 3 and check you've not got a crank seal leak.
Cheers both, Im erring towards this tbh. Its a pain having to do it twice but doing it in my mates barn with his lifts will make it less painful.
I was wondered if there could be a leak causing the slip, but it literally only slips when i've been hammering it for 30mins or so, and even then its only a slight raising in revs before it grips and is fine.
Soooo…. New injector in, checked the spark plugs just to make sure I had the right cylinder and pretty sure I did… no. 3
So went about changing it. I knew before i started what was about to happen, the fuel rail was pretty hard to get off due to oxidisation onto the injectors. But once off east enough to change.
all out back together and it started on the button but I’ve not got a cyclinder 4 misfire 🤣. Think I’ll just order 3 more injectors and be done with it.
View attachment 1625014View attachment 1625015View attachment 1625016
This has been a great read so far!
Don't suppose you could provide the AutoDoc part number for the injector you replaced could you?
If i order them now, they should be delivered by spring for me to fit.....
Thanks
Ben
Id probably send it, but if it goes from slipping a bit to slipping like fook in a few laps you will have a s**t day. Thats generally how it goes once they are done.
Cheers. I’m probably going to just send it at Cadwell in the 24th, not got time to do anything before then and it’s “only” £99 so could be worse.
I’ll need to get on with it after that though.
Thanks
Ben
I’ll see what I can dig out
Fitted the headlight covers, they are shocking quality so glad they were cheap. They look okay for what they are though.
Need to replace the handbrake cables as they are shot and don’t work anymore so another little job to do.
Adjusted the seating position as well. A good few hours spent at the barn.
Crap photo:
Really should take some photos from the barn, been over today for 4 hours,
- Handbrake cables replaced
- decat fitted
- horns removed
- brake ducts refitted
- tow loop fitted at the rear
- checked the seating position and set the belts for the HANS and helmet
Also ran diagnostics and had an error code for front o2 sensor no signal, but it appears to be working fine, I’ve ordered another anyway and will keep an eye on it.
Just save for getting my new wheels from @Mr Underhill in Tuesday it’s all ready to go on Monday at Cadwell, hope the weathers good.
Mint day at Cadwell, car was spot on all day. New wheels and tyres were 👌 weather was mixed but didn’t end up in the wall had a couple of small moments on a damp / wet track but applied liberal right foot and then sloped off to the pit to change my pants.
Sure some photos will follow that adequately show my immense driving skills.
