Clio 182 High CO2
Car  Rti and 182
Hey guys, im looking for advice,
My Clio 182 is failing mot in Portugal due to high co2, it’s supposed to be 0.30 and it’s double at 0.60-0.70. I have Optimiz acess catalyst converter and exhaust which is as close as we can get to oem quality, brand new Bosch lambda sensors, engine timing is perfect set with oem tools, and I’m not getting any warning on the dash. I also checked the map sensor and the seal is good and tried injector cleaner but still having the same issue.
One weird thing that is happening is when arriving there the idle levels are ok but after checking the levels accelerating the idle gets a high reading too. I’m pushing the car to its limits when going to mot to make the exhaust and cat really hot but no result.. any suggestions? Thanks
Can you check fuel trims via some diagnostic tool?
Check coolant temp sensor readings too.
Does the car idle ok?
The car idles ok and pulls very well too, I will try to have acess to a diagnostic tool with live data to check those
Another thing, how long have you had your cat? Has it passed before with the same cat? Any chance you could measure the inlet/outlet temperature with some IR thermometer? The outlet side should be much hotter if the cat is working ok (about 100C difference higher on the outlet as a rule of thumb)
A lot of posts on this forum have said over the years that it's good to get the car as hot as possible by driving it hard and then immediately after do the not emissions test.
I have the cat less than a year ago, was wondering how could I test the cat, I can definitely do that temperature test. Someone also told me any leaks before the cat would massively increase co2 but I think I would hear it straight away?? Was thinking to maybe spraying soapy water on the exhaust headers gasket and the headers itself..
Yeah a lot of people told me to do that, but I’m already pushing the car to its limits and not solving the issue
Temps look good
