Leaky camshaft plug caps?
20X Bumper wheelarch engine undertray screws clips for Renault Twingo Master | eBay UK
20 X WHEELARCH MUD GUARD FENDER BODY PANEL. ENGINE UNDERTRAY. RENAULT / VAUXHALL. SCREWS with WASHER.www.ebay.co.uk
I'm told these are as near to an original as you can get
Doncaster-ishWhere are you located Andy -
Raised the car and and placed on axel stands this afternoon.
I wanted to get ahead and free up any potential seized bolts. As it happens after a wire brush, everything freed up nicely.
No cutting required!
Looks like everything bush wise is original, all rubber on each bush have split. Inner rack boots cracked and split also. Good job it’s all being replaced.
View attachment 1742770View attachment 1742771View attachment 1742772
Both arch liners on near side and off side are undamaged which is a relief.
Removed to see if there are any issues lurking. Pleased to report all is good. Lots of s**t bottom of wing to sill which has now been removed. Will clean whole area once shocks have been removed.
Looks like I have a leak around the gearbox where the driveshaft slots into box. Any ideas what I need to replace? I was expecting the selector seal to be shagged, only a small amount of residue around the selector so dodged a bullet with that one. It doesn't stink like gearbox oil so it might be a engine leak from above.
Anyone know which arch liner screws I can use to replace current old screws? Same goes for the splitter?
I remember holding my 83yr old grans hand after she had died. She had died 3hrs earlier.
Her hand still looked younger than that.
You're on the dole you idiotWorking ands bud. Not like these soft northerner moisturised millennial hands of today.
f**king working hands. You're just an OAP
Not moisturising isn't a flex 😂😂😂😂You sound like a guy that moisturises…
If laying on your kitchen floor whilst your wife squats above me showering me in her golden piss whilst she swishes her choddy clit like a DJ on a set of decks. Then yes, I do moisturiseYou sound like a guy that moisturises…
Looking great Ant. I need to get on and do this with mine! P.S Let me know if you want to sell your original springs.
Did you drop the subframe to fit them?
Admittedly I employed Birchdown to change mine as I could not be arsed with the hassle.
Not needed on a road car, id be taking it off personally. Debatable if needed on a track car from experience too.
Oil will be too cool if no thermostatic plate.
And some new number plates Ant.
Right
ANT
Right
ANT
Why?
What are you using to remove the tackiness?Sort sticky interior in the usual places
Also which mats did you get?
I’d leave it.
Don’t use HG sticker remover or anything with solvents…. It cost me a dash top 🙄
Elbow grease spray is good enough to remove the stickness and what I should have stuck to using.
Elbow grease spray? 😆
Thank you!Not decided yet. I’ll start on the door card handles first and use a degreaser + brillo pad.
I purchased these.
Renault Clio Carpet Mats MK2 RS - 7711425548
Renault Clio Carpet Mats MK2 RS - Renault Parts Direct - Renault Parts Direct is a web based service from our authorised Renault dealer.renaultpartsdirect.co.uk
Those mats have dropped in price, unlike everything else for these cars.Not decided yet. I’ll start on the door card handles first and use a degreaser + brillo pad.
I purchased these.
Looking forward to seeing the end results - super cool thing
