Matthews Inferno Orange 182
Matthew_
Been meaning to start a build thread for just over a year, coincidentally that's also how long I've owned my Clio having bought it May 2024.
Previously had a Twingo RS with a bunch of modifications which was great. It was set up mint and cornered spot on but wanted felt like it needed more power when on track, I looked at doing the F4r engine swap like a lot have done in the past and I was so unsure on which direction to go as the Twingo had a good amount of money spent on it. It had a fully redone front end including powdercoated subframe, full powerflex bushings on all steering components, camber bolts, PMS Solid top mounts & strut brace, Evol engineering dogbone mount, a modified scorpion exhaust, plus bucket seats with a rear seat delete and a rear brace bar. But after alot of pondering I decided why not just get a Clio and then I can build a new car, so that's what happened.
I spent quite a while looking for the right one and ended up buying my Clio from chesterfield with just under 100k miles on the clock. While doing my research on it, it turned out to have an interesting past having lived in the isle of man for many years being confirmed by the seller after it was missing a lot of MOT history.
When I bought it, it definitely wasn't perfect. It rubbed horribly as it was fitted with 17" Turinis, needed belts doing, had no ac, had a coolant leak and the paintwork wasn't and still isn't perfect but I don't mind a project, I actually wanted one to make it mine and gives me something to learn on.
Photo from the day I bought it. With my mates Clio 197 F1 Edition which has had a Meglio swap done to it.
I instantly swapped my 16" genuine Clio turinis on to it, off of the Twingo
After a year of ownership it doesn't look too different to when I bought it but its had quite a bit of work done
Since owning the car the list of work I've done includes:
  • Swapped my 16" genuine Clio turinis on, off of the Twingo
  • Serviced
  • Fixed the leaky exhaust
  • New cambelt, dephasher, solenoid etc @ Birchdown (The lads at Birchdown are legends!)
  • New radiator, power steering pump & full ac setup replaced @Birchdown (fitted at the same time)
  • New front & rear badges and door bullets back to own (Wasn't a fan of the black badges)
  • Stopped it leaking from the boot and dried out the interior after the scuttle panel blocked up and the interior became a pond (including fixing the blockage in the scuttle panel so it doesn't happen again)
  • Fitted Powerflex Suspension bushes
  • Replaced inner tie rods, track rod ends & boots
  • Powerflex Camber bolts fitted
  • Alignment @ Demon Tweeks
  • Fitted Recaro trendlines seats
  • New alternator fitted
  • Cleaned up the front seatbelts with the pressure washer
  • Plus a bunch of other bits I've probably forgotten
There's a lot left to do trying to clean up the car as best as possible while also modifying it in an OEM+ style. Some of the things I still need to work are include:
  • Figure out the noise coming from the engine bay (I keep thinking I've fixed it but find a new noise. Its a whining/whirring noise but most of the belt components have been replaced)
  • Paint brakes
  • Repaint or clean up Upper & lower inlet manifolds, cambelt cover, fuel rail cover and throttle body (Undecided on direction of this yet)
  • Paint and fit battery cover
  • Change intake to a JMRS one (not sure on what colour to go for)
  • Replace front grille with a newly painted and cleaned up one (just waiting on new stickers)
  • Make pre tensioner covers for the Recaro trendlines
  • Polish headlights
  • Fix spoiler brake light
I will try and keep the thread updated and probably ask a bunch of questions along the way as I fumble my way through tidying and modifying 😁
Matthew_
Thought the first post in this thread was long enough already so here's a collection of photos from the last year of ownership to catch up
My old Twingo with the newly purchased Clio
ClioSport 2024 with our groups line up of Clios (Not sure but think we might like clios ahaha)
Cleaning up the seatbelts and a bit of maintenance
Some other images
Couldn't be without roofbars for it either
Matthew_
Looks like a decent base. Who the hell put 17's on it though 🤦.
Thanks, definitely a decent base especially being an Inferno orange so not very common which makes me want to do it justice. I thought the exact same, had a 2 hour drive home when I bought it and within 10 minutes I knew they had to go, think I cracked the bumper with them on the drive home 🫣
Matthew_
Bit of an update on the clio, been busy over the past few weeks trying to tidy up the clio with some small jobs. My main focus at the moment is the engine bay to make it nice and clean and the way I want it before I get some larger modifications later on in the year.
  • Polished Headlights
    • The headlights had some yellowing on them but I'd never tried to rectify this on a car I've owned so I was putting the job off. Originally I planned on using wet and dry paper before polishing but decided to give them a once over with a polisher, some menzerna 400 and then meguiars ultra finishing polish as a first try and if it didn't work I would get the wet and dry out. Luckily they came up great just using the polish and they are now really clear. I applied some fusso wax and sealant afterwards to them to give them some protection. I'm really pleased with how they came out and now knowing how simple it is to do I should have done them way sooner!
Before
After
  • Carried out the yearly service
  • Removed some rust from behind the rear number plate
    • I found some surface rust bubbles when going to fit the new rear number plate. So as a temporary fix I sanded it back to clean up all the rust and then got some colour matched spray cans and gave it a quick paint. Used a 2k primer, the colour matched spray paint and then a clear lacquer. The lacquer didn't come up very well and I didn't blend it all perfectly but it was again my first time doing it so I got out the polisher and managed to bring the clear coat up really nicely. It's definitely not perfect but as a first try I think it went well and the boot needs a full repaint anyway as it has a bunch of scratches on it so I will do that properly at some point.
Some photos of the rust
The finished paint job
  • Fitted new smaller number plate to the front
    • This transforms the front of the car and I love it. Definitely worth getting. I followed the guide on the forums and its so handy with the sizes and website.
  • Tidied up the fuse box so the lid could close and found a bunch of bodges (this is in preparation for the battery cover I will be fitting soon)
    • Ever since buying the clio the fuse box lid hasn't closed properly and so I took some time to figure out why. It turns out the positive cables from the battery to the fuse box have previously been cut and re-joined which was pushing the fuses up stopping the lid from closing. I tidied them up with new tape and properly separated them which allowed the fuses to clip in properly and the lid to close. I'm in 2 minds about fixing it as I want to fix it so its done properly but I'm scared of the french electrics. So I'm thinking do I just leave it as it works. Any advice would be appreciated.
Photos of the bodges
Thanks for reading :)
Matthew_
Recently I've been having 2 issues with the clio but I can't figure out fixes for and was wondering if the wonderful people on the forums had any suggestions?
Problem 1 - Clio wont start first time. If I just turn the key the car starts but instantly stalls and revs die. If I turn the key so all the lights on the dash come on and then off, then turn the car off and then back on and try and start it, it starts fine. This only started after replacing the alternator and after trying to start the car many times with broken alternators. Any suggestions would be appreciated
Problem 2 - A chirping / squealing noise from the engine bay (videos below) I've checked the belts and nothing seems to be rubbing, I've checked and the power steering fluid is full and the level hasn't changed. This has only started recently and is intermittent, the power steering pump, ac pump, tensioner, aux belt, cambelt, water pump and dephasher have all been replaced recently (On a side note the oil level since doing a service seems to have dropped but I am going to check this again tomorrow to see if it has lost any more or has levelled off now) Again any suggestions would be appreciated
Brigsy
  T.Turbo
Starting issue is most likely due to weak intank fuel pressure regulator on the fuel pump. Fuel pump only primes on 2nd on/off of ign, so first attempt without prime will be rough start or conk out. Wont be related to alternator, its just coincidence.
MLB
Mine has recently started doing this as well, what's the fix, new fuel pump time?
Brigsy
  T.Turbo
Yeah new sender and pump. I dont think reg is available separate, and to be fair pump wears out over time so if mileage is getting up there it will be due.
MLB
Since @Matthew_ will need one as well, any idea where best to get them from?
Just looked and there seem to be quite a few options. Seem cheap at £40 or am I looking at the wrong thing?
Matthew_
Ace thanks for the advice. The alternator was a nice red herring 😂 Seems like a few of us have had the same issue so super helpful!
Like @MLB said is it supposed to be that cheap or is there a specific brand that's recommended or are any ok?
