3,304 days ago since I owned a Renault ..
andybond
In tonight's episode of I did a thing : Part 342 Sill covers
My drivers side sill cover had split and was threatening to nip my inner thigh with its plastic jaws everytime I got in and out.
For reasons unknow I failed to get pictures of me removing this part and melting hot metal wire into the crack. Perhaps it was the toxic plastic fumes that came off the metal that caused me to forget. I also removed the wrap that was on the sill covers. It was a carbon wrap and was starting to show its age.
Anyway, the two major cracks are now held together with the metal wire and some filler made up of superglue that's subsequently sanded down.
Tonight I took them to the spraybooth* and painted them with stove paint. I have no idea how they will turn out but as long as they look 59% as good as before, Ill be happy.
* garden store.
MRBILLYUK
  FF Jeden Osiem Dwa
EBay!
I changed the drivers side door check strap yesterday.
It definitely looks different to the original one, but it works. No more clunking of the door when I open and close it 😁👍
One thing I have noticed with this check strap is, the door opens way more than with the original.
andybond
andybond
Gents, who make the OE pads for the 172 cup?
I have had enough of the worlds dustiest pads meaning every time I drive I have to clean the wheels as they look like they have been down t’pit for a week.
mumpy
  Clio II RS 172
Ant1
Brembo! Brembo! Brembo!
I fitted these TRW pads a few weeks ago. Dust is minimal for what they are, good bite and feel.
Absolutely silent also.
I paid £24 so it may be worth holding for a coupon or offer to come through if you stick on your watched list.
MRBILLYUK
  FF Jeden Osiem Dwa
There ya go, £24.79
I agree. The dust is minimal, they last for absolutely ages. They never seem to fade when hot and bite from cold is very good.
Brigsy
  T.Turbo
Id bet its had a replacement screen at some point, reusing the old seals which never seem to go back right
Daz...
  Inferno 182 Cup
They’re a terrible fit as said. I ended up sticking a dab of glue in the bits that slide together, that’s kept it in place just fine.
andybond
I have noticed that since its been drier than the Gobi desert my cup has started creaking. I note 3 distinct creaks.
1) Clutch. It doesnt feel terribly smooth and every depress of it results in a eeeeeeerrrrrrk sound like a comedy sound effect on a haunted house door open
2) Front right suspension. On compression it creaks. Its a short creak but a creak never the less.
3) Steering. When really slow and steering left or right I have two creaks that I think are related to the steering rack. The sound doesnt eminate from the suspension areas as far as I can tell.
Anyone have any quick checks for these? Or any simple remedies?
Matt Cup
  Leon Cupra, 172 Cup
@ex-Chinese Dave is the master of creaks, squeaks and knocks 🙃
andybond
Tonight I changed the front pads on the car from RS4-2 to OEM Brembo.
I desperately need my callipers refurbing but I am delighted that the grinding noises have stopped when braking.
I noted that there were cracks in the pads and in one corner it had disintegrated.
Whilst I had each respective wheel off I used some silicon grease on the ARB bush, and top mount
Squeaks be gone! Off on a 90 mi round trip to play football tomorrow. Let’s see how long it lasts.
andybond
My center part of the dash is scabby. I also need two vents.
How do you change these out? I know if you take the dash top off it takes the center part out , but what about removing the vents?
This bit :
