Matthews Inferno Orange 182
Continuing on with more photos
Painted the front end to bring it back to orange. Some before photos
Progress & full painted using 2k white primer, colour matched spray paint from a company local to me & hycote clear lacquer
While working on the engine bay I was also working to fit the new to me exhaust (the cgr I have posted about on here previously). I wanted to do the job properly so I bought a new exhaust hanger mount kit from Pro - Am, a pair of gram exhaust mount bush's and a new OEM centre exhaust hanger.
Alot of the bolts were quite rusty holding the hanger mounts to the car but alot of wd-40 later they all came off. The hangers had previously been worked on by someone, they were standard but had been diy'd to look like a powerflex style bush but it wasn't great and once cut out came apart very easily. Very glad I replaced them for some proper bushes.
I cut out the majority of the bush material and then used a flat head and a hammer to remove the remains around the edges and then a file clean up the final bits. Having spent a decent amount of time cleaning them up I was happy with the finish and went to put the gram bushes in only to find out these weren't genuine hangers! And they wouldn't fit properly 🫣 so I had to start the whole thing again and I ordered 2 used genuine hangers off eBay.
Lesson learned always check parts if they are genuine! Especially on old cars like these. I hope I don't make this mistake again 😂
New hangers arrived a few days later and I set about cleaning them up. AGAIN 😬 this time it was easier and I'd learnt how to do it better. So I cut the main hanger out and then used a combination of the flat head, hammer and a wire wheel on a drill to clean them up and they were done much quicker.
Then I got to fitting the new bushes and test fitting them all onto the car which all went smoothly.
Knowing it all fitted, I put the new middle exhaust hanger on the car and set about tidying up the exhaust surrounds on the rear bumper. I took inspiration/copied Mr Underhill's idea of using the rubber edging and it worked perfectly and looks miles better than the old plastic that was on there as the old ones were white and wouldn't clean up but I've kept them to try and bring them back to life later down the line.
I then went to fit the new exhaust. This is where it goes down hill again 🙃 the new exhaust is missing part of the metal rod that would sit inside the hanger, it doesn't look to be cut off it looks to have been manufactured this way so the car it came off must have had a different hanger setup which I wasn't aware was a thing.
In the picture below the yellow line is what is missing
So after all this work to fit the new exhaust I ended up refitting the current ktec system to the car (in the rain which was not fun) and I now have another job on the list to manufacture and weld a new hanger to the back box and get the exhaust on the car.
But overall the exhaust sits much better and there is less rattle so it's a positive and I've cleaned the car up which is the never ending goal. (I don't have a photo of the finished result 🙃)
Just a small job completed the other day. Boot lock on the Clio started making a horrible grinding noise whenever youd go to lock the car, luckily it is a common issue with a plastic piece snapping inside the boot locking mechanism and I found loads of information on the forums (Thanks again to the forums, saved me many times!)
Before video
New part was ordered and is now fitted and means the boot now sounds normal again
Gave the Clio a good clean after work today, it's not been cleaned since before I started the engine bay work which was far too long. It's all ready for Autos De France at Oulton Park on Saturday
Since doing the work on the engine bay I have developed a very small misfire on idle. It's hard to tell from the sound of it but it is there and the car only recognises the fault when it sits idle for a few minutes, if you then drive off with the warning light flashing within a minute or so the light disappears, it's very odd. Ive checked spark plugs they look alright and we're all tight so my next guess is injectors. Need to get my code reader working again and then I'll see if I can investigate further before ordering some injectors. If anyone has any other suggestions that would be great.
Alright fella. I think you were parked next to me this morning, sorry I didn’t stop to say hello before I shifted my car. Yours looked clean as hell btw 👍
Catching up on a lack of updating this thread
So back at the end of Sept I booked onto a trackday in the Clio at Oulton Park for the 15th Nov which meant I had a list of jobs I needed to sort relatively quickly to be ready in time. The list included:
Gearbox oil change
New front brake discs - Brembo High Carbon
New front brake pads - Ferodo DS2500
Brake bleed & flush using RBF 660 fluid
Swap over to my mates wheels & tyres (RPF1's with AD08r's on)
These sounded like relatively simple jobs to sort in time but I ended up leaving the jobs fairly late due to being busy (including working on a go kart which I need to start another thread on) so with 2 weeks to go before the trackday I began work on the brakes and of course they did not go to plan
Front brakes came off somewhat easily other than the passenger side caliper being seized so I ordered a set of new replacement calipers for both sides on the front (TRW / Lucas variation as this is the OEM manufacturer). So I buttoned the front up temporarily to come back to the following week as I still needed the car.
Then while I was doing the front brakes I was suggested to do the rears as I had rear discs sitting in the garage, so I bought a set of brembo rear pads from euro car parts and hoped these would be easy. The rears wen't on fairly easily but the rubber seals on the sliding pins and piston were perished or torn so I needed a rebuild kit to fix them. So again I buttoned the rears up temporarily while I waited on the big red rebuild kit.
As you do while I was waiting on the brake parts to arrive I was thinking of what else I could do and thought it would be a shame to leave the pair of bucket seats from my old twingo out of the car. It was like it was meant to be, I found an OMP drivers base on Facebook marketplace in Llandudno cheap and I was passing by there later that week so it would have been rude not to go pick it up. 1 OMP base purchase later I went about fitting the bucket seat to the Clio using the hardware from the Twingo as in this area they're basically identical. However, as I have read on here previously the OMP bases sit quite high so I spent many hours in the dark on the drive adjusting and readjusting on different side mounts to try and get a good seating position. Eventually I did get one all be it abit too high for long term use but good enough for the trackday. The OMP mount will be sold at somepoint and replaced with Jon Fozz mounts to get the right seating position (when I have another car and can put bucket seats in permanently)
But I wasn't done there, I got bored waiting to do the brakes and thought the rear seats were useless so I removed the rear seats, boot carpet and parcel shelf. This made driving round in the car a very loud experience but I don't mind cos its all abit of fun.
Having done all these extra jobs we now get to Tuesday the week of the trackday and the parts have arrived. I fix the rear brakes using just the rubber seals from the rebuild kit and then bleed the rear brakes with the help of a friend (I just pushed the pedal)
Then I go to fit the front brake calipers but the new drivers side caliper destroyed the threads on the braided brake line and inside itself meaning I couldn't refit the old caliper. Not what you need the week of a trackday, slight panic set in while I tried to find replacement lines at 10pm on a Tuesday night that I could fit on Wednesday. I resorted to ordering a tap & die kit from amazon for the next day delivery in size m10x1 (the size of the thread on the brake lines, Cliosport coming in clutch with this information) with a backup set of front HEL braided lines being ordered for delivery later in the week just in case. Coming back the next day with tap and die kit in hand and luckily for me the kit saved the day. It took about 45 minutes of trying to persuade the die onto the brake line threads but I managed to get purchase and gently managed to rebuild the threads. So after all of that the old caliper was placed back on the car with the new one firmly going back to the supplier under warranty. Alot of hassle to have got no further forwards but ah well.
The passenger side caliper went on a breeze in comparison and then we bled the front calipers (me on the pedal again)
Last job being a gearbox oil change which was simple enough and 3ltrs later the gearbox definitely feels better.
Mates wheels on and the car was ready for the trackday (baring a clean) with 2 days to spare! And of course to finish my collection of jobs going wrong I had to wash the car in the rain as I had no other time.
TLDR to sumarise
  • New Brembo front brake discs fitted
  • New Ferodo DS2500 brake pads fitted to the front
  • New front passenger side caliper fitted
  • New rear brake discs fitted (Genuine renault with wheel bearing)
  • Rubber seals replaced on rear calipers (both sides)
  • New Brembo rear brake pads fitted
  • Brake bleed & flush using RPF 660 brake fluid
  • Gearbox oil change
  • Drivers side bucket seat fitted
  • Rear seats & boot interior removed
  • RPF1's & AD08r's borrowed & fitted
Oulton Park 15th Nov Trackday was mega. Clio ran faultlessly, all the work paid off. Brakes felt really good and I'm pleased with the DS2500.
Shared the day with a bunch of mates in a collection of cars including:
Clio 172
JCW Mini
Yaris MK2
M4
Evo
Megane
+ a few more that I've forgotten
This was the first time I'd taken the clio on track and my first trackday at Oulton so I wasn't sure how the clio would do. I went in quite careful but built up confidence throughout the day and the clio was spot on, never missing a beat. There is so much more the car could do, passed where I was comfortable pushing it on the day but I had alot of fun getting quicker and quicker and learning how to drive the car better.
I did have one spin which was fun at the final corner but stayed on the tarmac and I learnt alot from it. Unfortunately for me I'd timed the spin just as all my mates had arrived at the final corner to watch, so it was captured in HD for all to see.
I've already been looking at dates for 2026 to get the clio out again and I will wait eagerly for the cliosport announcement to book some tracktime! It has confirmed my desire for a set of 15" wheels and a set of coilovers so they are on the 2026 shopping list.
Compulsory bucket seat track sticker was purchased and is now on the bucket seat, I'll slowly collect more tracks. (These are all the tracks the bucket seat has done across the cars I've owned (A twingo rs and the clio))
Since the trackday the clio has had the interior put back in and the bucket seat removed for the time being as for day to day use the recaro trendlines are much nicer.
Clio started juddering on the motorway on the way back from a weekend away in York but the misfire light wasn't illuminated on the dash so I thought it could be fuel as it was getting low but as I pulled off to get fuel I got the misfire light but only for a few seconds and then it cleared which was odd. So I brimmed the tank just in case but it only got worse. So stopped in a services had a quick look under the bonnet for anything obvious which there wasn't and decided to just phone the AA.
Luckily we only waited about 1.5hrs for them to arrive and we got the nicest AA guy ever, he checked everything he could but there was no obvious issues or reasons for the juddering so he followed us for a while on the dual carriage way to see if it persisted which unfortunately it did and so he dug further at another services. All he could figure out was he reckoned it was cylinder 2 and it could be a HT lead. So with no obvious fix I limped the car back home and set about finding a solution.
Obvious first things I planned on doing 1 by 1 to see what fixed it were:
  • Spark plugs
  • HT Leads
  • Injectors
Spark plugs were first as the correct spec can be bought from local retailers which meant I could try and fix it quickly plus in my ownership they have never been done. So new spark plugs fitted but they made no improvement although they needed changing as the old plugs had seen better days.
HT Leads were next ordered from KAM as this is what the AA guy had suggested as the potential cause. Bought the NGK HT leads and fitted them although they are definitely longer than the OEM ones but again this made no improvement.
Injectors - I bought a set of used injectors a while back but never fitted them as it turned out 1 was toast but I kept the working 3 as emergency spares for this exact situation. Fitted one of them to cylinder 2 and like magic the juddering went! So the clio's christmas present this year is a set of brand new oem injectors which I will look to get ordered and fitted in the new year.
Following on from just before Christmas when the Clio developed a misfire, new genuine injectors were ordered from autodoc, weirdly as I've seen mentioned before on CS they arrived in 2 boxes with 2 injectors in each. I had been meaning to fit them but due to rain didn't get chance and as the car was going to Birchdown for a check over I got them to fit them. So new injectors are now sorted and the car feels lovely. Will keep the old working ones as spares in case it happens again.
As I mentioned Clio went to Birchdown as I thought I could hear a knocking noise and it was pulling to left more than I would expect. Birchdown did a thorough inspection and other than top mount play they couldn't find any issues which is positive and so I will look to get the car aligned again in the near future to hopefully fix the slight left pulling. Just means more reason to buy the coilovers I've been looking at!
The day before the clio went into Birchdown I got a engine warning light on the dash with code P0420. The car drove fine but I asked them to take a look and it turned out the top O2 Sensor had worked its way loose and was letting air pass through so they tightened it back up and the code has cleared. Timing worked out well there.
Lastly I've been meaning to fit resistors to get rid of the seat airbag light and finally got round to it. We made up a set of plugs with resistors soldered onto the wires to make fitting and removal easier however when I plugged them in only 2 of them worked. I think it was the 2 for the seatbelt tensioner and not the actual airbag module, not quite sure why so I have fitted resistors straight into the plug instead for those 2. If anyone knows someone who can code out the airbag light instead that would be great as I would like to do it properly and not need to rely on the resistors as I've seen them not always work.
A very small addition but I got new genuine floormats for the Clio for christmas and so after a quick hoover got them fitted :D Just need to wet vac the carpets and the seats now.
Been eyeing up Speedline 2118 wheels for ages to go on the Clio but never managed to find the right set or be quick enough to buy them second hand so was looking to get them new until a set came up recently for sale on facebook from Mark Lloyd.
Knew I had to get them so travelled down on Saturday to Kidderminster and picked them up. I added to the purchase a set of ps3s he had which had about 6-7mm of tread on each. I'll get them fitted to the wheels soon and probably sell the ns2rs.
Very pleased with them and happy to finally have a set in my possession.
Need a good clean which will have to wait till after the trackday tomorrow but will be very soon.
I think they are ET 38 so suggestions on spacers for that offset would be appreciated. Don't really want to rub but would like to fill the arch
Mate you've got the nicest colour going with the inferno 👌 absolutely bang on. You've got me remeniscing now, worst thing I did was get rid of mine, still annoyed 12 years later!! From memory wasn't there only 167 made in inferno orange? Keep hold of that bus pal 👍
Thanks man I do love the colour, really stands out and catches peoples attention. Might be biased but I think its the best colour they came in. Ah what a shame that looks like a really good example of one as well but at least you got to enjoy one 😁. Do you know if your old one is still going?
I didn't know that about them that's very cool. Thanks I do plan on keeping it, I just need to not have it as my daily as the miles are quickly going up on it
Enjoyed the last trackday at Oulton so much I had to get another one booked while the prices were cheap so 3rd Feb Clio was back at Oulton for a trackday with Javelin joined by my friend in his Clio 172 he just bought back. Got very lucky with a dry day baring some snow just after lunch which didn't stick and the fact it was freezing all day but I'd rather it be dry and cold.
Clio went really well and felt really good like last time. Eyeing up a summer trackday at Anglesey and would like to try Donnington / Cadwell but will see what I get up to between go kart and Clio.
2 Issues from the day which turned out to be only minor
1. Had major vibrations and juddering on my final session before lunch from the front left corner. Thought the driveshaft was knackered, jacked up the car and when spinning the front wheels it looked more like a buckled wheel but it turned out the wheel bolts (which had been torqued cold at the start of the day to 105nm) had loosened off massively which was a concern as I've never had this happen on a trackday before. Torqued them back up and went back for a few test laps and all seemed fine. Happy they were ok I pushed again for a few sessions and again last session of the afternoon they had loosened back off enough to cause decent vibrations. None of the other corners had an issue and I've not experienced this before. I've not really driven the car since the trackday and have new wheel bolts arriving tomorrow to replace on all corners for safety.
2. The brakes started to fade in the afternoon and were getting quite hot so I will consider brake cooling ducts from the fog lights but I'm not set on definitely getting them as I want to keep it looking fairly standard with a fast road style. I will also look to re-bleed the brakes but the pedal is back to normal after letting everything cool down.
Otherwise the clio is mega on track and I can see why so many people turn them into track cars, I'd be very tempted to do the same.
Some photos from the day.
Any powdercoat in the tapered hole the studs go in? That can cause the studs to loosen off.
You could go a bit tighter on bolts than 105nm, 110nm wont hurt anything. M12 x 1.5 10.9 bolt will do 125nm safely dry torque.
On the other hand, they can back off with track use. My megane r26 wheel bolts need a retorque a couple of times on a trackday as they back off.
Not that I have seen but when I take the wheel off again I'll have another look thanks
Ah sound I'll up the torque a bit. I think I did go to 110nm when I tightened them in the afternoon as I'd seen someone say 110nm was ok.
Good to know, I have heard of bolts backing off with track use but didn't know how extreme it was so it could just be that and as I haven't experienced it before I might be over reacting.
Thanks for the heads up on it :)
The bolts are all quite rusty and seem old so good excuse to replace them and if it happens on the next trackday I know I was over reacting ahaha.
My disastra used to back wheel bolts off on the front left. It was always that side so ended up swapping the hub (it’s one assembly with 3 bolts to remove so dead easy) and that did the trick on that. Turned out at next tyre swap that the wheel was slightly bucked and it wasn’t when the last ones went on so put it down to either vibrations working them out or the hub itself being dodgy after the wheel took a whack. I didn’t replace the wheel, just balanced it back up. Never had it before, never had it since. Would prefer to never have it again 🤣
As @Brigsy says though, I’ve heard of it happening on powdercoated wheels too where it’s on the seat for the bolts.
Ah very interesting and really good to know. I did wonder about the hub.
I'll keep an eye on it and if the new wheel bolts start to come loose, I've got directions as to what to investigate first so thank you 😊
Haha yeah would prefer to never have it again 😂
Good updates. What's the tread like on the NS2r's if you still have them?
Also, your left washer jet cover is keeping me awake at night. 😅
I know I know but they're bonded to the bumper and bodywork isn't my area of expertise (although none of this is 😂) so I'm not sure how to get them off without damaging the bumper so I need to look into it. Got lots of excuses as to why I haven't changed them 🫣
NS2R tread is 4mm, 4.5mm, 6.5mm, 6.5mm.
Lovely looking car. Ill second what Sam said further above.
I had two and sold them many moons ago but wouldn’t love another baked bean. Loved them!
New to me 2118s have been fitted to the Clio along with the new wheel bolts (done a while ago just getting round to posting)
Everyones seen a Clio with 2118s on but here's a photo incase you haven't. Needs lowering further and some spacers but that's a future project.
Clio also had it's MOT today which it passed 😁 got lucky tho as before the test I thought I best check the lights so it didn't fail on something silly. Good job I did it turned out the fog light plugs weren't connected fully or at all so neither worked. 5 mins of stress wondering why and a nice simple fix later were all good.
Looks decent on the 2118's.
Front fogs not part of mot so no need to worry on that one
I thought if the lights were present then they had to work? If they had been removed completely then they obviously cannot test them.
Quite a few different adventures & jobs for my Clio over the last few months.
Starting at the start
1. Swapped the AD08's off the 2118's in favour for Pilot Sport 3's which I had waiting to go on. At the same time I gave the wheels and the wheel arches a good clean.
2. Clio worked Go Kart duty again
3. Went on a holiday to the Cotswolds and then onwards to Goodwood for the members meeting. Clio was faultless (not but it was only a minor issue) but it did around 800 miles and was a lovely drive. Nice to finally get to Goodwood and be in the Clio. The Cotswolds could do with better roads, the size of some of the potholes and some are unavoidable!
And a few super tourers because they are so cool!
4. Clio made a friend at the petrol station. Lad I follow on Instagram who used to own a Twingo RS like myself but has upgraded to a Megane
5. Been looking at getting a wet vac for ages and my GF bought one for me so spent some time cleaning the seats, carpets & mats in the Clio. The amount of dirt that came out was very satisfying
6. Clio was back on holiday duty. This time off to Morfa Nefyn in North Wales for a camping trip.
7. Clio has a new friend now, after being a work horse recently and being up to 115k miles its time for it to have some TLC and take the role as weekend / fun car.
Now onto the little issue the Clio has had over the last few months. While on our way to the Cotswolds the passenger window went down but wouldn't come back up. After some gentle persuasion (me pulling the window back up while my GF pressed the window switch) we got the window closed and didn't dare try it again. Once back home I took a look and it seemed the window would go down but not up. So after some googling and reading some threads I presumed it was the window regulator. I took the door apart to take a closer look before ordering the part but nothing seems obviously broken. So I tried the window again and the problem has changed now the window will go down and up but only by a very small amount and then just stops.
I've felt the guides at the front and back of the window and the runner for the window regulator all seem free and clean. I suspect its a faulty window regulator but wondered if anyone had experienced this or had any advice as the problem keeps on changing.
Video to show what is currently happening.
