F31 35d, Skoda Yeti
If you zoom in there's a pen on the clamp for scale.
Big stuff!
That's only half the job, it's a gearbox for a crane. The day spakka has already drilled some holes in the wrong place and we've not got onto any of the tight tolerance stuff yet 🙄😂.
The machine has a 60 pot carousel, 4m in x, 3 in y, 1.5 in z and 0.75 in w with rotary table with 12 tonne load capacity. I love big jobs 😁.Is all of the stuff you do manual tool changes or does it have automatic changes?
More room in the tool changer would be great. This gearbox is 3880mm long so myachine is the only one big enough to get it all in one. I'm not sure how old the machine is, early 2000`s I think but it's been quite reliable in the 4 years I've been here considering preventative maintenance is non existent. The other week the day spakka said it had a spindle overheat alarm on all day and yeah the cooler tank was completely empty so it would do wouldn't it 🙄.Thats amazing!
These MAGs have 42 on the carousel and then 36 or so on the chain.
No where near the XYZ size though! Thats crazy stuff.
Not long changed the high pressure coolant pump on one tonight. It has lasted just under 10 years so not too bad, but getting to that age now with the constant use that things are failing
I have ran two machines for the last 30+ years. It's fine if you have no problems but can be a mare if one goes wrong.This isn't just Porl, it's all the UK machinists I've ever met!! In China they probably have 10 machines to each person and get deaded if they forget to tap a thread.
What if both go wrong? 😂I have ran two machines for the last 30+ years. It's fine if you have no problems but can be a mare if one goes wrong.
😂Then it’s double trouble but that rarely happens thankfully.What if both go wrong? 😂
