CNC thread
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
That's only half the job, it's a gearbox for a crane. The day spakka has already drilled some holes in the wrong place and we've not got onto any of the tight tolerance stuff yet 🙄😂.
Is all of the stuff you do manual tool changes or does it have automatic changes?
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
The machine has a 60 pot carousel, 4m in x, 3 in y, 1.5 in z and 0.75 in w with rotary table with 12 tonne load capacity. I love big jobs 😁.
Thats amazing!
These MAGs have 42 on the carousel and then 36 or so on the chain.
No where near the XYZ size though! Thats crazy stuff.
Not long changed the high pressure coolant pump on one tonight. It has lasted just under 10 years so not too bad, but getting to that age now with the constant use that things are failing
OssPoop
Thats amazing!
More room in the tool changer would be great. This gearbox is 3880mm long so myachine is the only one big enough to get it all in one. I'm not sure how old the machine is, early 2000`s I think but it's been quite reliable in the 4 years I've been here considering preventative maintenance is non existent. The other week the day spakka said it had a spindle overheat alarm on all day and yeah the cooler tank was completely empty so it would do wouldn't it 🙄.
OssPoop
On to plan B 😂.
Only a dozen holes left to do. And the fitted studs don't fit in the holes 🤷🏻😂.
