What the hell is annealed?Was the copper gasket properly annealed?
I would give it another go using better nuts, inconel studs and either tab washers or NordLock washers before going to the expense/hassle of getting the manifold and turbine housing ground perfectly flat to be able to run without a gasket. Looking at that manifold flange face it needs a lick over for anything to seal regardless
You can heat copper up and quench it to bring back it's original shape and squishynessWhat the hell is annealed?
Ok I’ve looked into the annealing process looks easy and I’ve managed to find somewhere that will let me use there oxyacetylene
What that video doesn’t say is should I fit the gasket immediately after or can I anneal it like a day later or a hour later etc
In my mind the quicker I get it fitted the better but it probably doesn’t matter I’ll be doing the annealing later today thanks in advance
