182 Touge/Tuner Build
looking at that ball joint above its not been fully seated and someone has battered in the pinch bolt anyway, assume ripping the threads clean off the pinch bolt so it will have been moving up and down in the hub, as above probably damaging the hub.
With the above fixed if there's still issues swap out the rear dampers. (i chased an issue years ago, leading to a full front end rebuild and it still wouldn't drive properly, couldn't get to the bottom of it until one of the rear dampers started knocking, changed the pair and the problem was completely solved!
I remember when my rear shocks were properly toast on my 182, every drain cover or mild bump in the road shot me sideways like a f**king D1 drift king 🤣
That makes sense. I’ve been working through a fair bit of bodge from probably several of the 17 previous owners of this car, so it figures that whoever did the previous balljoint was smoothbrained.
I’ll get a fresh set of rear shocks on it and see if that alleviates things. Rear shocks don’t look to be too awful a job, so I’ll just get on it next time I send the Clio into air jail.
Thanks for the extra perspective, I’d’ve never even considered rear shocks to be a potential issue so I’d just be chasing my tail with a front end rebuild. Seriously appreciate that!
Sounds exactly like what I’m having! Any imperfection, I’m getting pulled about and anything big I’m getting shot broadside 🤣
Loading the car up on anything other than a smooth roundabout feels like the thing wants to flip over 🤣🤣
Who you calling smoothbrained?!
As one of the previous owners, you can check my build thread on it? I don't recall doing the ball joints, could have been me to be fair... 😅
Having had it on track it handled really well when I briefly owned it.
When you say turns left more than right, do you mean lock to lock? Is the rack centralised?
LMAO the bits that aren't broken are the bits you've done, don't you worry lol
And yeah, rack was all sorted and done properly. Just a geo issue, I think hubs/rear shocks as mentioned.
This is the ongoing shithousery in question.
I'm a fairly avid enjoyer of the Clio's autistic Japanese cousin (the K12 March/Micra) and had an opportunity to get hands on this.
It's already bought and secured, but I've got 6 cars as-is and ideally need to downscale to 3.
If Cliosport is okay with me sticking around with my weird Japanese not-Clio, I'd love to hang around nonetheless
I thought the K12 Micra was based on the MK2?
From what I can find and some quick, cursory measuring, the rear axle mountings are identical to that of a Mk3. A rear disc conversion may be on the cards as I did similar to my EJ9 back in the day, so will report back when (likely quite far down the line) I attempt it.
The front brakes, at a glance, look exactly like a Clio mk2 setup though. I have some un-fitted Hispec 4-pots and may attempt some silly buggery over the winter.
Clio's up and (properly) listed. This actually feels quite sad to do. Sorry chaps.
I've put it up for £2800, but I'd rather it go to a good home in here, so if someone here is keen on it for whatever reason, I'll happily look after them on the price.
I also successfully identified the source of my handling woes as the rear discs/bearings going off, which I'll either have done ASAFP before sale, or will discount accordingly for the price of a set and labour fitting them. More than happy to honour this either way. 🫡
2005 Clio 182RS
J41 Arctic Blue
Shell: 176k miles
Engine: 80k miles
Exterior:
Carbon fiber vented bonnet
Clear taillights (can revert to standard)
Standard alloys
Single wiper conversion (can revert to standard)
Engine:
Milltek exhaust with resonator
Rallyefab induction kit
RamAir cold air intake
Cup alternator & pulley setup, AC removed
Suspension & handling:
Powerflex Black bushes all around
Cup shocks
Cooksport 30mm lowering springs
Ferodo DS2500 pads
Brembo HC discs
Interior:
Nardi Personal steering wheel (genuine with paperwork)
MOMO steering wheel boss (genuine with paperwork)
Cruise control fitted, working on steering wheel
Will come with standard alcantara/leather seats instead of Sparcos
Rear seats removed with false floor that I made myself
Aye. I kept them on after de-livery-ing the car as they felt a bit more subtle/tasteful.
If the sentiment's to bin them off entirely, good shout.
This pal, if you want a wider audience for your sale then the more standard the better tbh. Shame you haven’t got a blue bonnet to replace the carbon one too.
Mrs finally had enough then?
Thankfully not, she's fully supportive of the atrocities I am attempting to commit to a Nissan Micra.
2/3 of the living room is currently being used as a garment factory by her to make a dress in time for Goodwood.
God bless both of us being the exact same caliber of severely f**king autistic
IF it were me (and last time I checked you aren't me), I'd remove the stickers, and replace rear lights and the bonnet for standard.
Edit* can see your looking for a bonnet.
Got a set of standard tails going on this weekend, stickers ditto. :)
Bonnet hunting, but I'm at the point where it's more of a "I need the space" than a "I need the £" issue.
Standard seats are back in, and standard taillights back on. Un-pimping my ride to decommission the thing before sale.
Given the nature of the next build and the fact I'm getting my own unit, I'm really going to miss the time spent with the boys tweaking the Clio. The car brought a surprising amount of people together, and I'd never really had the crucial car guy experience of hanging out at a unit until I got this.
Have this wonderful image taken while the work was ongoing.
You e definitely got some axle stands under there haven’t you….
That's my mate underneath the Clio/between my legs (😳) and I did say to him "are you gonna put something underneath the car?"
Given he's got like 12 RSs sat in his barn, I think he'd be fairly content being squished by one in all fairness. He's also a farmer, so "health and safety" isn't in his vocabulary
Oh well if it’s your mate that’s fine then…f**k him.
In all seriousness, I know it’s not cool. But that is sketchy as f**k.
Aye! Even though it was a truck jack, I personally wouldn't get under there and do it without some kind of failsafe. I've driven someone to Halfords before just to forcibly purchase eyewear for them before using an angle grinder :ROFLMAO:
...I also don't own Crocs, nor would I be seen dead in a set, for future reference
I definitely wouldn't get under there and do that myself. At minimum a thick steelie under the car, or ideally axle stands *and* a steelie.
Either way, it be like that, my mate mate didn't get squished thankfully
