induction coil?
Car  RSTUNER'ED-C&B'ED RS-1
Hi All
For a Mk1 RS 172
There is a three-cable connector plugged onto the induction coil with black, white and red wires.
By any chance does anybody knows which one shows what?
Ground, Signal, Excitation?
Thanks for the answers
earth and 2 triggers - its a wasted spark system so theres a signal for each bank of 2.
I am just trying to get the wideband installed, I am gonna make logs of AFR vs RPM data. For RPM data capture, I have got an MSD Tach Signal GMR Pickup cable. Basically, it clips to a coil pack’s voltage wire to produce a common 12-volt signal. I need to figure out which cable is ground and voltage wire.
