Time Attack Build Begins (Cage in!!!)
looking good :) loving the white and carbon
i just mounted my cooler to my bumper lol its a weird configuration but its getting lots of air
Looking top mate! How have you fixed the door cards? I've got a big sheet of 4mm stuff so I'm going to make my own. Square metre was £100 off Not Normal on here and iut weighs feck all so can't really go wrong................................He says :o
well these are light enough to be held in place with 25mm wide double sided tape. there is no chance the originals i got from PT would of stayed in place with that.
Tho having said that, the door isnt totally flush, so i did rivet it twice in the bottom corner.
time attack should be fun! you will need a good few weeks to get used to that engine! sort out any bugs etc!
This should stay in place with that easy enough. I did think velcro too though???
Also, with rivets I did'nt want to have to drill them out if I take them off.....
When's the engine due mate??
hopefully there will be no 'bugs'. engine is spending 2 days on the rollers, so will be mapped to within an inch of its life by Andy and Richard of Omex.
Its more the handling that i will need to get use to, rather than the engine.
First round is April 6th at Donnington, so not long.
You still taking yours to the 'Ring next month Ben? hope all the 'bugs' are ironed out for you too!
i did think about velcro, but thought it may hang out too far, as its not the slimest of stuff.
engine starts going in this weekend!
Yeah hopefully it will be sweet! I’m sure Andy will be spending hours getting it to run right! If you have commitment to do the labour for free as part of a sponsorship then you have it in you to get it running tip top!
I thought about rivitting some plates on the inside so the velcro sits flat with the door skin as a pose to sticking it too the skin. If that makes sense?? lol.
there is a slight ridge infront of the speaker where the card wont sit flush
you could use a self tapper there which will just unscrew out!
there is a ridge around that area on the mk1 aswell
it got the hammer treatment to flatten it down lol :evil:
Coming along nicely, Wish I had a Track Toy :(
White and Black with CF Bits look Amazing
What about rivnuts in the doors and some nice looking anodised screws through the cards into the rivnuts?
Have you seen how i attached my door cards?
Just self tap screws and black numberplate covers.
Cheep, does the job well and easily removable
Elaborate!! :o
I thought about those actually as they wont stick out against the carbon!
Donnington is a defo... gonna try my best for Knockhill, but its a good 12-14 hour drive from me!!
i wont get the car back from GDI till that weekend, so gonna have to miss out.
will be doing GoodWood at some point tho!
doh! just realised you said 21st of APRIL! i read it as MARCH! what a div.
what company is that with?
easytrack, i saw that there was a white clio going so thought i may be you,
although just read again, its a 98db day, i think you may be over that?
ok....
well picked car up from Mark Fish, he welded in my seat rails, which now allows me to sit central to the steering wheel, top job as always!
Then took car up to GDI to have engine fitted
so dropped off a few parts to allowed the job to get done, like a new set of engine mounts, oil cooler pipes and my freshly ceramic coated 182 manifold...
Whilst there took some pics of the bottom end (head is being fitted monday)
Also took a few pics of the other goodies that are part of the build..
Helix uprated clutch
ATP bodies
Lightened and balanced fly wheel
If all goes to plan, should be looking at getting the car back in just over a week!
btw i've just fitted my oil cooler along with the cc manifold as you know and my oil temp now wont rise above 2 below the half way mark its uber cool just worried it's too cool ;)
It can be too cool, it should have a thormostat that only lets oil round the rad when it gets to a certain temperature
As above, a thermostatic plate will only let oil through when it gets hot enough to warrant it. Cold oil can be just as bad as hot oil.
Car looks great BTW fella, top work!
have you had the oil channels tidied up, as a performance f4r block has problems with oil flow, just bore them out to head gasket, and tidy up sharp casting edges, we had problems with big ends going in the rally car, this cured the problem, what pistons? are those wossener?? what power you going for?? anything more than 220 and you will find snapped drive shafts and fubared gearbox, sadav dog box reccomended, hissingsid has one for sale :cool:, and one last thing if you have high lift cams be carefull with valves, they snap!!! :mad:
