What engine you running how much power have you got are you on the throttle or off when getting the under steer could be the tyres or you trying to get on the power to soon
ben i think you will find that your rear springs are two soft for the fronts i would try 500lb rear springs .
also what make of springs are they on the car ben as if they are ebach then as long as they are not damaged or marked in any way they will swap them for you
theres your problem matey, try 28 in the front, our rally car runs at 24 in the front if its dry!!! :rasp:front 33
rear 31
id say problem is powerflexes. if you tighten arb in front then you understeer more
With your spring setup you should not get any understeer
Tyre pressures are not that important
I would check the health of your rear ARB, maybe buy a ph3 rear beam with stiffer ARB
And do buy wishbones from newer model (ph2), they have more caster built in
Your alignment looks fine, u need more camber for trackdays (-2.5)
Try spacers at the front
lol f**k paying eibach prices (£230 for 4) each time LOL
That seems a tad steep. I only paid 30 quid each for eibachs for my mates 205. Just get the new stuff. U know what im talking about!!![]()
im still not convinced. the new LEDA stuff looks awsome!
they had financial difficulty and went into administration, doesnt mean that they have now lost all the experance they had! LEDA have 30+ years if not more. Im sure that a new set of LEDA's would easily out perform the AST clio kit.
And you also made the point that LEDA's are oil filled, every person who got a set of LEDA's back from the 2005 group buy could have had the option of Gas.
