The everlasting ph1 ITB Build **GREEN-BUILD STARTS AT PAGE 100**
M
mini-valver
Re: someph-ing different...........
I love that stance dude! Fill the gap between your drive and the road with some tarmac, it'll go on ;)
The only thing about the Konigs that I didn't like when fitting them to Middo's is the lack of thread on the damper to hold the top mount on, only just enough for the nut! Otherwise they were brilliant!
Nafoff
front's or rears?
rears - on the rears we noticed a lack of thread coming through and i am sure i read about this problem somewhere, we rectified this by simply turning one of the rubber grommets the other way up, this gave us loads of thread to play with.
fronts - james noticed this problem and was struggling to tighten the 10mm bolt on the top of the strut to keep the hole lot together, once we fitted the top mounts to them we noticed that the bolt that sat right on top of the strut now inbetween the top cup and the bottom of the top mount was literally doing nothing, so we removed that, it is all held in firm and fast now with the bolt on the top of the top mount.
love it mate think the yellow goes very well, like it alot mate, take it the other air duct on the drivers side does feck all
  BMW E46 330i Touring
Stance looks awesome dude, brings it all together very nicely. I can see how it might be impractical though!
Reckon you should spray all the front and rear badges black...
Nafoff
cheers guys
something i may be looking into ads, but if the rears go black so will the front, sorry limca i would rather keep it now,
cheers justin, may not be using them now anyways
Nafoff
i am turning into a pic ***** i am sure.
anyways, i ended up last week booking this week off for no reason, so with a week free i decided that i would go for the cars first proper clean of the year, i have a visit to wincanton motorsport tomorrow also for the coilover set-up so it is a car week.
well the car started off outside the house, for ease of worrk i wanted it on the drive, but as me and the bumper found out the other day it won't go on the drive, and just to prove it..
before then
after that fun, ended up using planks of wood, i then set about cleaning it, first up was a wash, washed with nxt wash.
once this was done i then set about claying it with megs quick clay (seems alot easier to use than the mothers i was using previous)
i then washed and dried again.
i decided next that i was going to get the wheels off and properly wax, polish and seal them, rears first as that end was easier to jack up.
the wheel treatment included Autoglym Extra Gloss Protection left for an hour each wheel and then 2 coats of Poorboys wheel sealant.
and then the fronts, whilst these were off i decided to try and higher the coilovers aswell before i visit the garage tomorrow
too much?
another piece of work today was to look at my prospeed exhaust, i had a stealth fitted quite a while ago, but for my liking it sat a little too low, too visable, i popped back and spoke to charlie but he said it was ashigh as it could go, so the next best thing i thought was to disguise it as best as possible, with the car being lower the easiest way i felt was to paint the bit you see black, this will reduce reflections and therefor disguise it more underneath the car
before pic only, forgot the after
lol.....seriously though, this is how it currently sits
Marky_
Clean \o/
Not the biggest fan of titanium ph1s (too common ;)) but i love yours. Needs shorter aerial.
Nafoff
i know about the aerial, thing is i am not sure what fits, where i can get one from.
ideas??? it is on my to do list
Marky_
Got mine from Halfrauds. It's £10-ish and about 1/3 the length of the fishing rod :D
Nafoff
will look into that then, i heard pug's and citreon's fitted them too, just not any other bloody renault...lol
Marky_
I think they are the same fitting as some of the pugs and citroens....
Nafoff
right 2 pictures to show the difference in height......
better ones tomorrow.....
extremely low
set - up low
  e60 M5 -172- dciheid
christ first one is good bye front bumper on that driveway
- good work
Nafoff
just for you ads
and a quick side on pic to show it spangly and also to show the set-up height
before
set - up
going out this afternoon for proper pics
and a few pics to show how i meant about the exhaust
here you go...
closer
and just to prove it is actually there
the top pics kind of show that its doing its job really lol
  172 Race Car
Good job on the exhaust, I always thought it was abit low.
Did the motorsport place set the ride height for you aswell?
Excellent mate, the properly set-up heights actually make the original ones a bit silly!
The rear looks about the same but the front looks more level now, spot on.
Nafoff
the rear is the same, the front went up, had a look under there this morning and you can see a clean lline in the driveshaft were when it was too low it was rubbing the chassis
Jon.L
  911 GTS & Macan GTS
love this car mate perfect. any other plans for it?
mace¬
  Clio
^^^ Really liking this to, what are the next plans?
OK answered, stripped and caged?
Nafoff
this will be updated in a few days i suspect...i have something new
a car cover.....this girl is going to sleep for 3 months
may get it stripped and bucketed for the time its ion the road again
  53 Clio's & counting
nice one matey, gotta get a cage,it will compliment the cage perfectly,as long as you dont do anything silly like spray it kawasaki green........lol
Looks good, where abouts in somerset are you? Will have to keep an eye.. being in Radstock :)
Nafoff
i am in shepton mallet but work in bath so commute every other day in this old girl, but not for 3 months now as i can't drive.
Jon.L
  911 GTS & Macan GTS
i love this car. how do you get ur side strips so black ive tried everythign they just go back to a dull grey/black
