K4M Project Blog
  • Thread starter Thread starter mini-valver
  • Start date Start date
definetely seems to be making progress. i'll grab some proper pics when im able to get my grubby mits on it :approve:
I'm low on funds! I have an ICV now off a Vauxhall ecotec so Ben's sorting fittings and shiz his end for mapping. I've started the theme Im going for too with sprayed badges, Ill get pics when I get time as its pissing it down. I've given the plenum 2 mins with Autosol and its come up brilliant so that will have some time spent on it too.
Alot of things are money dependant ATM so I've been servicing stuff, stripped the brakes and cleaned/greased the sliders etc to get rid of the "twang" in the pedal. Now it seems to have a notch so I'll check the drums when it's dry. Middo has got a week off soon so he's gonna be getting busy with the G220 to see which bits of car I have to get sprayed ;)
I will dude as soon as I can fuel the fecker and its mapped! Im currently just running the filter from inside the Maxogen too, LOUD, lol!
Nice to see the project ticking over, it's always easy to put things on hold when funds are unavailable. I am needing to get my ass in to gear with my exhaust, talking of keeping things ticking over :o
Pics of the tarless interior? Bet that was a thankless task :(
Tar was easy Gem, took about an hour to do it all. Took the airbag loom, airbag and ecu out aswell but I cant get the light to go off. Any ideas? I cut and crimped the loom under the dash an taped it up but without the ECU etc it should go out right?
Steve, Thats too much effort ;)
Rogue relay, open circuit, somewhere?
Failing that, just take the bulb out the dash lol? Also, you got any of that white spirit left? (I don't want my boss to shout at me for stealing lol :p)
nope the light stays on with the ecu removed, you'll need to either find the signal line that goes fromt the ecu to the instrument cluster, and earth it...
or take the cluster apart and stick tape over the bulb
Bulb out it is then. Gem, the loom is literally hacked off, then I used a crimp on each wire on the off chance I need to put it all back in again, Ill just crimp the other side back on, lol.
Yeah, still got loads of that white spirit! Spilt a bit in the car though so it stinks.
For once I'm proud I've come up with a solution :o
Coolio....I'll pick it up at some point in the 8 weeks free I've got :p
I've got used to the slacker comments TBH. Teachers do no work obviously....ever....;) Lol.
Lol, steady! There are many reasons why I'm a teacher...making children cry is not one of them :o
Now if you don't mind, I'm going to stop spammming Dave's thread.....:S
Bah! Duck you're the instigator.....;)
Dave, you know it makes sense...get out there and get something done. Beer, pizza, tools. Job done.
About time I made some sort of update, lol. The car is going back down to Angelworks this week for mapping and to sort the ICV setup so haven't really done much as I wanna do it all when the car is finished (mostly bodywork related). I'm short of money ATM so have been doing little bits that are free ;)
I've been sorting a headlight feed all this week and I'm pretty happy with the reults. All I need to do is work out howto get a dual elemant bulb for main and dipped beam to work in the existing dipped beam place. Took a fair bit of cutting, filing and fiddling to get it to sit right too, should provide PLENTY of cold air for the filter now!!
I had to cut the trumpet to the shape of the light, took some doing with a junior hacksaw and a file but I got there.. Pics of it fitted tommorrow!!
that is farking cool. But if im honest, I'm worried that you will never get the full beams working properly
I've got a few ideas, one of them is to try and cut another hole for te min beam bulb next to the dip beam, lol.
Anyone have an ideas of how the dual elemant bulbs are wired?
See what it looks like on the car tommorrow now the silicone is dry, hopefully will reduce inlet temps a fair bit too as its just an open filter behind the light ATM!
