What size is the air feed pipe on the standard 172 FF airbox
I am offshore at the moment so can't go out to my car to look. Does anyone know what the size the standard air feed ducting is that goes into the standard airbox on a 2002 172FF from the wing (with acoustic valve removed) ? I was having a look on Ebay for ducting but was unsure what size i needed :(
There's two . Ones 70mm and ones 60mm .
Any ideas which is which bud ?
As i wouldn't mind uprating them. :)
And has anyone any good suppliers of ducting pipe ?
Or like my original plan would Ebay be the best bet ?
And would a couple of metres for each feed be enough ? :S
Would a metre be long enough ?
I guessing it may be the bottom air feed that is 50mm.
As the one in the side (from wing) looks bigger than that.
The one to the acoustic valve is 60mm , the other , shorter one is 70mm .
get two metrs length.. then you can feed all the way down to the arch and cut some off. Very frustrating when mounting and finding out they're too short
Venair supplies the ducts in your country
Bit of a stupid question but when you buy 1 metre of CAF is that 1 metre unstrechted or fully stretched?
I got my ITG panel filter the other day and now looking to remove the AV and run some better CAF's
