Re: My Ph1 172 track sl*g Progress Thread
Now, the best bit........ while I was doing this my neighbor said that madness can be cured but i am beyond help.
While at the scrappy the other day getting the altornator, I picked up (for the huge price of 8!) a Citroen AX wiper linkage (the single arm one)
Here you can see the difference of the linkages....
First I took the motor off the Citroen one as I wanted to use the Clio motor to save me having to dick about with the wiring.
Then took the Clio motor off its linkage.
Trial fitted the ax motor to the clio linkage to make sure the holes line up.............. and they did!!
So fitted the Clio motor to the AX linkage..........
and checked the clearance. The Clio motor being a very similar size but has a cover on it.
Next I offered it up to the car and realised it needed to be mounted further left towards the centre. The original wiper linkage mount was in the way.
So I made some room with the grinder. Hello old friend! :evil:
Took the plenham of to give me some room.
and went nuts
Managed to get the new linkage central, even using one of the original mounting points and bolt.
Loosely put a wiper arm on it to check the positioning.
After several trial and error's, I needed to make some more room for the linkage. It couldn't move through its whole cycle due to more metal in the way.
better, but still catched in places. more trial, grind more off and try again untill i ended up with this.
Bolted the linkage in using the old bolt spaced up abit with a nut and used a pair of mole grips to hold it steady while i tested the operation.
A little vid of it working well........
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zmYWzgA0XsE&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zmYWzgA0XsE&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
So happy that the grinding work was done I cleaned it all up and gave it a quick paint to prevent rust.
All the bits of metal removed. 0.5kgs!
Obviously the mole grips couldn't stay so i drilled a new hole in the linkage to secure it to the bulkhead, the standard AX linkage mount hole not being in the idea place as it wasnt sitting flush with the body.
Lined it up and drilled the bulkhead.
and fitted in.
Had to remove the washer and cut the bolt down as it was very very close to the linkage when in operation. Or too close to the expansion bottle on the other side.
Roughly weighed the old liknage, both arms and blades before I started, then when id finished, the new setup.
Standard Clio = 3.9kgs
Burp
speed linkage = 1.8kgs
AND 0.5kgs of metal was binned.
Weight wasn't the main reason I did it. Its different, frees up some space under the scuttle for a future plan and looks cool
I need to experiment with different arms, blade lenghts, alignement and park position to get the best sweep, but it currently works like this..........
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/TqL0xrlr88k&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/TqL0xrlr88k&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Wonder if this idea will be copied by anyone......
