Re: Valver Track Car Project Thread
Ive been flat out with work over the past few weeks, so had very little time to get much done on the car and get this updated. Managed a few hours during the week so I thought I ought to update and keep this thread alive.
Now that my engine was out, I set about dropping the subframe. Several reasons for this. Firstly now was going to be as good a time as any with no engine in the way. Secondly I want to give it and the engine bay a good clean and more than likely paint the bay. Thirdly because I plan on running a Williams/19 16v Widetrack setup at the front, and this includes changing the wishbones and ARB, both of which will be easier off the car. If I can get hold of an ARB and a pair of 'bones then I can build from the ground upwards rather than put it back together with old 16v parts and change it later on. Lastly, because I want to get rid of the power assisted steering.
Removing it consists of undoing 6 bolts, 2 front, 2 rear and 1 at each side holding the 'arms' on. 5 came out without a problem, however one of the rear bolts uses a supposed captive nut, and unsuprisingly this wasnt as captive as it should be, and started turning. So I prised the captive part of things out the way and managed to get a spanner on instead. It then came out fine and the subframe was on the floor once I'd taken the brakes off and undone the bolts which hold the struts to the hub.
I'd decided quite a while back that I wanted to get rid of the PAS and had been looking into the different ways of going about it. It turned out the manual rack and column from a 1.2 or similar needs well over 4 turns to go from lock to lock. Standard 16v rack is bang on 3 turns and I believe the Williams rack is slightly less. My 182 is also somewhere around 3. So having ruled that out I needed to decide on a different method. Some run the standard rack all sealed off and dry, but following a joint decision between Daz (my assistant :clown
and I we decided to run it sealed and lubricated.
We first removed all the existing PAS pipework to see what we were left with
On his Cup, Daz has basically made a loop pipe out of one of the existing pipes to go between the 2 ports on the rack, so we set about doing the same to this one.
Pipe bending, very complicated task lol
The 'finished' loop. It remains to be seen whether it's going to be in the way of the gear linkage when everything goes back together, but if there's a problem then it can be moved/bent out the way. Will be 'reet!
Filled with fluid:
I also sealed off the 4 ports by the column joint but didnt picture it.
And there we (hopefully) have one finished manual rack!
Had a quick rearrange/tidy up of the garage as it was a bit of a state and shifted the engine over
A few random parts have arrived too
Subframeless car with the strut brace layed ontop
That's all for now, will try my best to get some more work done but lack of time as usual. 7 day week ftl!
Decat on its way for the 182 too
Chris
