Burpspeed - From The beginning
  172 Race Car
Went in to see the hydralics pipe man on wednesday, he said he didnt have any gas to weld my pipe up and it might be a few days. Told him i wasnt in a rush but he rang me 4 hours later and said it was done! Legend tbh.
£31 to join the two bits of pipe and did a great job as before. Looked good untill I painted it, Lol
Got a few little bits done during the week.
track rod ends on and threads cleaned up ready for set up.
Sprayed the back of the passenger seat to tidy it up a bit. looks much better. Shame about the front. Gonna get my old dear to see if she can glue the cover back on or something for me.
Rain was forcast for today so wasnt sure how much would get done.
Yet again Dan (Shadowness) came over to lend a hand.
I fitted the newly made pas pipe.
And finished off the loom and relay for it.
Ran the wire through for the cooling fan overide and tested.
While I did that Dan stripped the front brakes down as I managed to get some discs this week.
I wanted to remove the ABS sensors but they were 'In there' so had to get medievil with them. Ended up cutting the hub carrier.
Stud conversion was fitted to the hubs.
And new disc on, again with the previosuly loved Greenstuff (*spits on the floor), brake pads
A year ago (Here) I rigged up my clutch ratchet to stop it auto adjusting. At the time it wasnt engaging the clutch properly when changing gear at high revs. You would just crash the gears. But with a new clucth im hoping this mod/bodge isnt needed anymore. So removed them for now so it can do its job. (kept them handy if needed)
We filled up and tested the pas system and found no leaks.
Fitted the induction piping
So we were making amazing progress, the sun was out and it was looking like it could go down on its wheels again. Bomber came over to pick up some tyres and gave an extra hand.
Front wheels went on
Ran some cable to the interior. Might change this later to some better stuff.
Almost finished the wiring for the cut out switch
Then down on its wheels for a quick run around the street, check the clutch and gearbox, pas, brakes etc.
Turned her around on the driveway for some rear end attention next weekend. shouldn't be far off an mot after that.
Bomber had a little spin in it around the street.
Im super happy with the way it looks sat on the drive right now, the rear ride height on the AST's looks so good. It may have to go down a little at the front tho. Front bumper looks good, needs a spliter, will keep an eye out for something cheap and suitable.
After todays acheivements, I have a big grin on my face tbh
Ph1%20Build%202
Nice work once again...
I had a NIGHTMARE getting those ABS sensors out too, but I ended up milling them out as they were off the car at the time
  172 Race Car
I thought about taking the whole lot off and taking them to a mates garage to get them out but felt it would eb a backwards step to take stuff off id just fitted, Lol.
Still got the back to do yet :rolleyes: hope they come out easier
Nice, great progress btw.
I will text you in the week about the disks fella.
Cant wait to see this again.
SHE LIVES!!!
Cant believe we got it moving, was quite weird to see actually, considering what it was like when I first saw the car months ago!
  172 Race Car
Good luck m8! Im sure it will be fine :)
Did you manage to get the passenger seat sorted?
Seeing my old dear on sunday, will get her to have a look then. Might look out for another one like I had before, ive still got the subframe for it
It'll sail through with your handywork.
Booked any days yet?
No not yet, Apart from 2 sessions at the Practical Performance Car Magazine show at Mallory Park in May. Need to do a day before that if I can.
Probably going to do FCS and Bedford in June
  C63 AMG, F430 & 172
Burb is your brake set-up like this?
The pink dildo is the bias valve, master cylinder is black.
cheers
  C63 AMG, F430 & 172
Sweet! I took it all out lastnight, just ordered all my lines!
Also go the AC matrix out. That was fun :/ Just ended up smahing the f**k out of it with a lump hammer.
Bought a 1.2 non aircon matrix today!
  #174
Just read this thread for start to finish for the second time! Great read!
Nice to see something different, good luck with the mot!
I'm at mallory too, havn't booked any track time yet tho.
  Qashcow
aye mallory should be good, i'll be there too.
finers crossed for the MOT, cant see anything major failing anyway
  172 Race Car
Thanks mate, make sure you come and say Hi at mallory. Me and Bomber will be with the Built4track guys
  172 Race Car
Not alot more needs doing to get it MOT ready.
The battery has been on charge in the back of my van all week and deffo its fecked!
Need to get another on tuesday (dam bank holiday)
Turned my attention to the rear brakes.
Took off the pad carrier and gave the discs a clean up.
Found a pad on the O/S had been sticking and worn on a funny angle
Everything seems free on the caliper now but I did have a little problem with it on the mot last year where it was binding slightly. Put it down to being parked up for a few moths coz after a few aplications of the handbrake it freed off.
Will have to keep an eye on this.
Decided to leave the rear abs sensors in for now. If I have to take off the hubs for camber adjustment then I'll get them out then. Just cut the wires off for now.
Rear abs loom out..
Fitted the studs to the rear
New pads fitted.
Popped the wheels on (one has lost some air coz the bead is leaking, another job for later)
Found a puddle in the passenger footwell, its been bone dry all winter inside the car. Been parked the other way on the sloping drive for a week and this happens.
Another job for another day.
Decided to tackle the heat sheild. Planned to attatch it to the egnine instead of the bulkhead this time. So the plenham had to come off again (are you keeping count?)
Used the old one i had and cut it down a bit, idealy needed a new piece as this is a bit small but it will do the job just fine. Needed something to keep the heat away from the master cylinder.
Fitted to the manifold studs
Engine put back together again...........
So apart form the battery, she is MOT ready. a few things to check, lights etc and clear out all the crap but I think that will do for now.
Still havent got a replacment for the broken rear helper springs, hopefully the tester will realise that they dont actually do anything and wont fail it.
  ITB'd MK1
if you can't get new helper springs in time, just remove the broken ones. they're not true helper springs really (WAY to soft for that), just keep the spring located so it doesn't come loose when you jack the car up
MarkCup
Ooh, studs, gonna have to get me some of them. Changing wheels without them is a pain in the arse.
Great progress as usual Jay. Next trackday, I want a ride :evil:
  172 Race Car
Looking at it it might not be possible to take them out coz the spiring isnt long enuff to adjust them without. Will see what the tester says.
Studs kit is available on ebay for about 35 quid, real easy to fit, you could do it your self.
http://cgi.ebay.co.uk/Stud-conversion-kit-Renault
James5_GTT
  R5 GTT
This is fantastic matey just read all from the begining. Going to get my one of those studs sets
  172 Race Car
Really? Even with my ability to f*** up the most seemingly basic tasks?
you can take the wheels off cant you. so therefore you just have to put a little thread lock on the studs and screw them in with a screwdriver............. Easy?
Nafoff
yerp i am also looking at the stud conversion now, will be much easier to locate the wheels when studs are on, something i am looking at sorting within the next few weeks
  172 Race Car
Sorted out my insurance this morning. Ended up with Adrian Flux £350 fully comp with my Doris on the policy too.
That's the kind of price I want to pay at my ripe old age. 30 with 9yrs ncb.
Not the £600 odd I was paying last year.
Starts on the 28th :)
  172 Race Car
Thread update
Decided to buy a new battery instead of dicking around with the old one. A direct replacement for the one I had was over £130!
Had a chat with the guy in my local battery specialist who sells stuff to race teams regularly. I ended up with an Odyssey 680, basically the same as a Redtop 25. He has used this type to start F3000 cars in the past. Its more than man enough and at £75 not cheap but better/safer than a normal car battery.
Only weighs 7kgs too....
Problem then was it wouldn't fit the lovely Adeyspec battery box.
DanR was over to help get all the battery cables in neat. We bolted the battery straight to the floor (more holes!) using the top of the battery box Adey made. It will be secured better at a later date.
Dan then made up some new cables using high quality cable. He's a perfectionist and made a very nice job of it. Better than me, the king of bodge.
We just need to secure and insulate the cables in a few places soon.
So after id put the seatbelts in, we had checked the lights and had a quick subway, it was down to the mot centre at 3pm.
I was bricking it tbh. Id had so much of the car apart, I was worried I may have left something loose. I don't know the guys very well down there but its literally 300yards from my house and they only charge £25.
The guy doing the test was 137 years old and didn't look to impressed with my handywork, Lol.
No mention of the tw*t strip at all (failed on that last year and I had to rip it off) he was a little worried by the missing abs system at first tho.
The emisions were spot on. That phase2 cat did the job. Last year (with the original cat on) it was a little slow to warm up and the CO was very high initialy.
Then came the problem!!
Handbrake efficiency low! 15%.
Minimum needed to pass was 16%
Fail! :dapprove:
New pads and only 300yards to bed them in, no wonder.
While the 189 year old guy had been doing the test, Id been chatting to the owner of the garage. He has a very mad Mini. Its a turbocharged A series. It runs at 200bhp before the nos, Lol. It has a quaife straight cut box that you can hear the otherside of town. Love it!
Anyway he lent me some trade plates so I could take the car out for a spin to try and bed the pads in. So completely unexpectedly I had a nice little run around the town in it.
40mins later it was back on the mot ramp and it JUST scraped through with 16%.
Pass! :D
  Mk2 172
Was a good day mate :) still far from finished with your battery stuff but at least its all safe and secure and WORKING which is always a good thing :)
Ill be round to finish it off.
  172 Race Car
Legend
Yea was a good day. had a little play in my car, got her mot'd, went out for a curry (cant move now im so full) and staggered home after a bottle of wine.
Yep, a good day
