Same seats as JamesStone IIRC!
Loving the work... Sets the standard of what mine needs to be like!
what have you used for the blank?
I just used a rubber grommet LOL
Meh!
If ever there was a masively complicated way of doing something, thats usually how I would do it! Anyway, this mod is proven to take 0.6 sec of a lap of Brands indy circuit! :rasp:
Looking very good, but don't forget after a couple of rallies it won't look as pretty![]()
great work chap, really impressive, would be good to pop down at some point and have a look
I know. I'm going to be heartbroken the first time I damage it! As long as it starts off pretty thats the main thing!
I know that you rally your Clio in the forests rather than on tarmac, but what breaks on your car, or what have you had to beef up? Just wandering if there is anything I'm going to need in my spares.
check with a scutineer about your cage mountings as i have just finnished a historic spec sunbeam and welded my cage in like yours it was a bolt in one the same as yours he would not give the car a MSA logbook as the cage should have been bolted in and not weldedso i had to drill and bolt the cage before he would log book it .yet my mk1 clio was no problem as the cage for that was a propper weld in one , also the seat rails should have mounting plates on the ends where they mount on the floor
No our car is both tarmack and forest, and believe me some tarmack single venues are rougher than forests:dead:.
On the breakage piont it depends on how hard you push, I would see what breaks then ask me how to make it unbreakable:S. If I was to tell you what and how you would have to start building the car again![]()
No problems! PM me when you want to pop down Neil.
I hope to get it MOT'd and taxed again soon, so that I can complete a few road miles in it.
Sounds like you had a right jobs worth of a scrutineer log book your car! I should be fine as this is the same as my last car, and the same guy will be log booking the new car. Won't be too much of a problem to add in the bolts anyway.
What do you mean about the seat rails? A strengthening plate on the floor where the seat rails join?
Thanks for the info.
Yes I agree mine has a small plate on the sill side, just cut a peice and simply weld round to make it look right, can't see it falling.yes mate you need to weld a plate to the tunnel and the innercill where the rails are going i made mine about 1"bigger alround than the rails weld them in then weld the rails to them (abit like the cage mountings)
you need them on both sides of the rail now also if its not logbooked yet you will need fia dated seats and clear safety film on the side glass(like window tint but clear) all these came in on 1/1/2009 for new build cars
will do chap, will give you a fair bit of notice...
FIA spec fuel sampling drain too.
Pisses me off as I'm never going to do an FIA event, so why the fcuk do I need an FIA fuel drain?! Not like many MSA events have fuel testing facilities!
The seats are brand new and FIA approved. Wouldn't have bought anything else. I also knew about the window film. Not sure wether to film the standard glass, or replace with perspex. Pros and cons to both. :S
Think I'm going to try and get the car log booked as is at the moment, and see if I can get it through. If not, I will have to burn more paint, and weld the plates on.
Do you know what the springs are now?Little update:
Won some FK coil overs from eBay on the cheap. Been told that they are FK Highsports:
One of the inserts is buggered and needs replacing, but thats ok as I only bought them for the bodies. Going to try and replace them with Bilstein inserts instead, but if that doesn't work I can always get a pair of new FK inserts for £185 all in. Are they any good?
Going to get some new longer springs too, to get rid of the helper springs. Don't need them to go super low anyway. What spring rates would people who compete in their Clios recommend? The car will only be used for single venue tarmac events, and I try to steer clear of anything too rough!
Any help will be greatfully received!![]()
at a guess 250 tend to run 350 on mk1 track cars
Not sure... About 200?
That seems really high. A mate of mine was running 240's on his Corsa rally car.
Just looked up the Renault Sport parts, but being french they are metric...
Ragnotti Gp N : 6Kg
Clio Cup Rally : 5.5Kg
Super 1600 : 5.5Kg
I'm guessing that they are measured in KG per Cm?
Doesn't look like the Bilstein inserts will fit... Diameter of Bilstein insert is smaller than the FK's. Would mean getting a sleeve machined to fit them, which won't be cost effective.
How good are FK's?
