Nitrogen instead of air? Tyre filled for £1 !!
  Lionel Richie
The Kwik-Fit Group is the largest independent automotive parts, repair and replacement specialist in Europe and one of the largest in the world. With 1,800 service outlets across Europe it employs 9,000 people. Kwik-Fit has national UK coverage of 595 service centres and more than 200 mobile tyre fitting vehicles, making it the UK’s leading tyre, exhaust, brake and MoT specialist.
HOW?
  Golf GTD Mk7
it is supposed to be of benefit on the track i believe. something to do with constant preasure when hot.
  Lionel Richie
its not really something i would bother with, top end motorsport, maybe (dried air is more common)
track day warriors, erm no
  It's A Reno
£4 to fill your tyres?
Tell you what, I've got a packet of dehydrated nitrogen in the garage. I'll send it to you if you want. You just add water and you're there.
ForceIndia
  Gentlemans spec 200
78% of air is nitrogen. So your paying £4 to replace some of the remaining 12%. Clever.
  Lionel Richie
^plus you won't replace the remaining percentage anyway, i doubt kwik-fit will vaccum the tyres down and then fill them, infact i'll put £100 on it
Djw John
Scotland - South
Costco do it as well, but dont charge you extra for the privelege (sp).
Now I realise might surprise some people but I cant tell any difference with it!!! Chraging for it is easy money!
ANd they give you hideous green dust caps... Which were nicked within a week thank f**k.
  260% JCW
We use Nitrogen on Fighter Jets in work, here's some crap info i found whilst bored at work:
Pros And Cons of Nitrogen Gas For Inflating Car Tires
Pros
  • Nitrogen reduces the running temperature of the tyre. The moisture content of nitrogen leads to a cooler running tyre, which is advantageous when the car is operating at its maximum load and speed capacity.
  • Nitrogen in tyres improves the ride quality. That gas is very slightly lighter than air and thus, benefits the tires in terms of un-sprung weight.
  • It is assumed that Nitrogen increases tyre life. It reduces the operating temperature during times of load and speed and thus, enhances the life of a tyre.
  • It is believed that nitrogen keeps tyre pressures more constant. The gas is assumed to provide more stable pressure range in connection to the tyre temperature. However, again, the factor is applicable in times of heavy load/high-speed conditions.
  • Tyres are susceptible to loss of pressure as a result of being porous in nature. Due to its chemical structure, Nitrogen leak out slowly as compared to compressed air. Therefore, it slows the rate of pressure loss.
  • Oxygen reacts with the tyre and rim materials causing oxidation or the rust formation in the metal parts. Nitrogen, being an inert gas, does not react with the tyre and rim materials.
Cons
  • Inflating tires with Nitrogen is quite costly.
  • Filling tyres with nitrogen requires more maintenance as compared to compressed gas.
  • The availability factor is the biggest disadvantage of inflating tyres with nitrogen, as the gas is not readily available. It is usually found only with specialist tyre dealers.
Steve
  LMC10, Puma E
Unless they vacuum the tyre first which they don't your wasting your time.
As 1 bar will already be in tyre before you start, defeating the object.
Your biggest enemy is moisture which we all see when using garage crap equipment.
  Titanium 182
I have nitrogen in my tyres but only because my uncle owns a tyre fitters and puts it in for free.
No difference to normal air at all.
Con.
  2004 Clio Sport 182
i work for kwikfit and tbh the nitrogen is awesome i use it in my 182 and have also started using it in my 2007 zx6 motorcycle tyres and the tyre stays hotter for longer and trust me you can feel the difference more with the bike for sure
  Astra SRI/ Hornet
I have been looking into this too, impreza owners swear by it, a fella told me it stops your car from following the undulations in the road which the Clio does suffer from, worth a try just for 4 quid.
KDF
  Audi TT Stronic
I believe some of the above about more consistent pressures and the other advantages of inert gas, but stopping your car from tramlining... em no. lol
TheEvilGiraffe
Don't be so ridiculous. It's a hover engine you want if you don't like tarmac !
:D
Before i do, what does the remaining 22% consist of?
From wiki
Air is a mixture of 78.03% nitrogen, 20.99% oxygen, 0.94% argon, 0.03% carbon dioxide, 0.01% hydrogen, 0.00123% Neon, 0.0004% helium, 0.00005% krypton, 0.000006% xenon.[1]
  Astra SRI/ Hornet
Might be an idea to pop a wee bit of common sense in though!
Sorry mr f**king know it all but when ya know nothing on the subject how could I comment when this guy had actually done it. I know you all pretend to know everything but it helps to actually listen to people who have experienced it first.
ForceIndia
  Gentlemans spec 200
The info's in this thread dearest. Air is 78% Nitrogen. The idea of the remaining 22% making a significant (or even noticeable), doesn't make much sense.
  It's A Reno
Look Kylie, taking things too seriously last night got sticky.
Don't do it again ffs.
