182 rear axle advice!
Car  clio 200
hi all,
i currently have a 182 rep and put a 182 rear beam onto it! however, the abs light is on on the dash, is there any ways of getting rid of it? ie fuse? e.t.c. any help/ideas/suggestions would be great!
Thanks
Ben
Did your 1.2 have abs?? Are you using disc brakes now?? The number of teeth on a abs rotor on a disc is different to the number inside a drum.
The number of teeth shouldn't matter a toss, as the ABS ring just monitors rotation, not how many there are. I'd say check the sensors!
Yehh has got abs, and its got discs all round atm!
But ile have a look at the number of teeth and like the other guy said have a go a filing some down e.t.c.
Also, i wasnt planning on taking the fuse out, just wondered if it might need replacing, or going to a bigger one ie 20a e.t.c.
