should i swap my clio for this polo with turbo conversion
Trader Rating - 99%
95   1   0
  Za**** & Xr250R
Re: shud i swap my clio for this polo with turbo conversion
That look's lovely that does but the milgae is a bit high tbh it does look like a clean example :)
Trader Rating - 100%
20   0   0
  BMW 330D
The fact they state they only took it in p/x yesterday would suggest to me something might be wrong somewhere.
1   0   0
  A red missile
car has a slight oil leak, noisy wheel bearing which will be sorted before it goes and the exhaust is bowing as the manifold gasket is perished i do have a new 1 which will be supplied with the car
open to sensible offers
Oh yeah? run a mile mate, high miler with possibly bad engine problems, looks a nice motor but I wouldn't take a chance on it.
JCC
21   0   0
Something tells me it's right up your street.
Trader Rating - 83.3%
10   2   0
  Honda & VW
No- the only 6n2 shape Polo you want to be looking at it the few with the 1.8t vw/audi engine - this one could well be a bad egg!!!
14   0   0
That engine will not last running 15 psi through it, i'd know as I have 3 friends with G40 turbo engines in there mk2/3 polos. Looks a good car, nothing wrong with mileage as long as it been looked after. Wouldn't go for it though as it has an 'oil leak', will probably be a bottomless pit of money to fix it!
6   0   0
  ValverInBits
That'll go pop!
No it won't. G40 is a solid motor. However. it'll need a new turbo to get past 200. That's the ONLY reason I wouldn't swap. Otherwise I'd swap. The 6N2 GTIs hold value very well.
Ali
2   0   0
  V6, Trackhawk, GTS
Mate, it's a conversion...You'll have endless problems! It's part and partial of this type of motoring.
POP!
6   0   0
  ValverInBits
Conversions have their problems, but if that conversion was done simply, then it shouldn't have reliability issues. A good mate of mine runs a G40 turbo and doesent suffer from reliability issues. I'm not saying it's a daily mileage cruncher, but don't put it down on the basis that the supercharger is an expensive fix (this'n doesent have one!) etc
9   0   0
  Petrol Blue 182.
My mate originaly built this with a standerd g40 engine. was f**king s**t hot quick! it had no reliabilty issues, when he built it and was the first g40 conversion in a 6n2 i belive
Trader Rating - 0%
0   0   0
  Polo G40 & Clio 17Poo
Mine runs 23psi. With no problems.
Who are these 'mates' with turbo'd G40s??
The little G40 bottom ends are good for 300bhp if you know what you're doing.
As for fixing it, parts are about 50p, and always fitted with a 10, 13 or 17mm spanner :rasp:
If it's a silver 6n2 I'd steer clear, the initial conversion was a proper job, now it doesn't look that way.
14   0   0
Do you know James that works for WikidWheels? I've seen a couple of his builds :S. But then I guess if you throw half decent money at it I guess they'll be alright (decent rebuild with decent turbo+manifold etc etc, which is probably why most of the ones I know have gone pop!
