In the process of doing a set of valver steelies for the track car. Going from dark grey to white, taken half a can to do one wheel so far and looking good.
any pics? althouth i thought steelies where a big no for track use?
just amazing how easy it is to change the colouris it textured?
How long does it take to dry fully? it says 45 mins but didnt know if it was being abit of a jimmy
Going to a meet today so I should get some pics up mategot any pics of yours mate ^^^^^
I know there heavy but didnt realise that about the heat, sure they will be ok for now. The car was previously used competitively with no problems im aware of. Anyway.. few pics of the first wheel i did (ignore the awful masking), will clean the tires and stuff when there all back on.
Before
After
I really like that it's a nice shade! How easy was it to use on your trim wouldn't mind doing that to mine tbh! Did ya have to remove the trim first or just mask it off?
Some already used the transparant spray for bonnet?
Like an invisible bra?
Here's a couple of mine.
As I mentioned the other day I'm not 100% happy with them, you can see on the first picture that it's started to peel of already.
how long is this stuff ment to stay on for? any advances on a month?
how do you clean them nickw99? and how often mate?
Well these are what £16.50 delivered per can? That's twice the cost of aerosol paint.
Fair enough you may factor in priming, but unless the wheels are damaged (and even then you can get away with spot priming) then a scuff up with a scoth pad will be fine for basecoat. Plus most of the examples I have seen above are solid colours, so you could just buy direct gloss paint, no need for lacquer then.
I thought about it as it did seem easier to just clean the wheel and paint (plastidip), but I'm not worried about removing it again (differing ideas on whether it is actually that easy to remove anyway), and would want it to be durable, so using the plastidip route, from what I've read, you'd need the plastidip primer, paint and lacquer. Same process other than keying up, and more expensive.
