well, more the cams. High comp with 421's would be a nice graph to see (although I've seen it done, and IMO the cams held the engine back at that point) and 422's with stock pistons, remachined with larger valve pockets is also an interesting proposition. There are a lot more combinations to achieve different things than the obvious popular waysOf course, obvious and popular is normally cheaper and easier, hence popular
did it all last night. Did u enjoy your drive home?Very true![]()
Did you get your prep finished today boys?
Very impressive, congrats guys! Good luck with the season!![]()
Yeah it was ok, knackered thoughSlight issue with the tps, but it will be sorted soon. Good effort on finishing it up last night. So have you come to the conclusion your CAN wiring was correct and the box is knackered?
Good result there chaps , good luck for the season :race:
Fookin wyas!Was nice to meet you both again. Glad the dash issue is sorted and Jay can feel more confident about his wiring![]()
We went up a few weeks ago and despite a small problem with the fuel lines, all went well. The new engine was run in on the dyno and the low RPM stuff all sorted pretty quickly. It made a decent power figure but Matt at TDf thought there was more to be gained. The theory being that the carbon airbox we ran before was causing a restriction with the new spec engine. we took the box off completely and the car instantly gained 6bhp. We left it as it was and went back to sort out a different filter for it and try again.
Thanks Yanoo, gearbox kit is doing well. Köszönöm szépen
It certainly sounds the part from the outside! I have just looked at the video that I got but it's not great! I will try and upload it tomorrowSounds good from the inside too
Thanks
Lee
James
Mike
for your help today.
Yes and from me, thanks chaps,makes life so much easierThanks
Lee
James
Mike
More than welcome mateIt certainly sounds the part from the outside! I have just looked at the video that I got but it's not great! I will try and upload it tomorrow
Thanks for having me, It was great for me to get an insight into how you guys run the car and really appreciate all the support and advice you have both given me!
Was hoping to pop in and surprise you today but got lost so was running late for work, was only about 20 miles away all day![]()
