Toastfrenzy's Tin Top, some say...........
The pictures look great Pete, I wish I had some decent ones of mine from track but I'm always too stingy to buy them from the organiser lol!
That is good going with the tyres my 888's have done a mostly damp day at Snetterton, dry day at Donington and a couple of hours at Bruntingthorpe and two of them are really low on tread!
If the car is setup/balanced well and driven properly the tyres will last. Im so surprised how many laps we get out of ours nowadays. Back in 2010 we were killing a set in no time. And were going a s**t load faster
Thinking of getting one of these Covers for the Cup as it always gets covered in dust, rubbish, bird muck in the barn. It gets wet too at times if the wind is in the wrong direction.
£150 or there about's they do one to fit a Clio.
Any one bought one or use similar?
looks very similar to ours. Just dont let wasps near it
Yes I guess this will come with experience and playing around with setups, I remember Tony mentioned that you used to get through yours at a similar rate of knots! I was surprised and very jealous by seeing how mint both yours and Pete's tyres were looking at the end of the day lol
I had a look at these at Autosport along with a few others and they seemed to be the best for outdoor, they also do a really good band which goes over the cover so you can use it on the car whilst towing :)
Bit of a post Brands pre Snetterton (30th March) clean and inspection on the Cup today, wheels off and cleaned by Scarlett. All bolts nuts checked, fluids checked, bit of oil missing so replaced that. Also fitted my false drivers floor, puts feet in a really good position plus looks CooOol too (Harry said it did).
Replaced the two fire extinguisher pulls, cut an routed\connected to the top of handle before (would've pulled and nothing would've happened). All routed and connected fine now. Harry stuck on some more stickers and I made an angled mount for the shift light, so it's more in the bottom of our sight line. Still got to get some Velcro to stick it down with.
Going to take the pax seat out, sub frame and rails on Friday lunch whilst at Snetterton. Got a track day, each got an instructor session in the morning, Ards at 1230, then rest of track day in the afternoon. Sam hasn't driven the new and improved car without a pax or seat, it's then 80-90 kg lighter. Even she'll notice the difference...why I stuck the shift light a bit higher so she'll remember to change up and not dither, shall I - shan't I..ooh it's not that far to the corner...
We've also turned into tree huggers now , had solar panels fitted this week....
Snetterton 30-3-2012, Track day and ARDS for Sam and Pete.
Was a good day all round, weather looked like another hot one but it cooled to around 12 degrees slightly overcast but was (I think) perfect. Cup was good all day, though the pax side nut that holds the front suspension into the AST top mount keeps unwinding, have to get some lock wire or loctite on there me thinks. With the new cams have a lot more straight line speed and had the edge on most of the Clios there but for some reason I kept watching them in the rear view mirror and then loosing any gains in the turns.....got to stop that..maybe the novelty of these new cams will wear off soon. Think I miffed a few of them off as had to let them pass on a few occasions...think it was the rate I left them behind out of corners, with all the tuition and I think I have got to grips (sort of) with trail braking, the Cup is pointing in a straight line (sooner) round a bend and I can get full power down a lot sooner. Though must still wait for the corner to come to me and not the other way round...
Now running a lot faster round Snetterton, as long as there was no traffic having carried enough speed could stay in third for all the corners, lots less to do now, with the extra torque and power available.....maybe I will get some TB's over winter...
The Piper Stealth measured 98db at the noise test.
Sam had a good day too, shift lights work well for her, though on the time that I pax'd round with her she is a bit too agricultural with her down shifts and sometimes up shifts too. Actually spending the hours with instructors seemed to bring home that an unsettled car is harder to control than a balanced one. Neither of us can heel and toe..not even tried yet, far too much going on and that's next on the challenge list. With out prompting she had already worked out the difference with the car and no need for using 2nd on the track and that to stay in forth for the 1st corner. It was a manic day with over 100 cars and I think in total around 12 red flags, with some quite bad accidents and one run out of fuel incident...every one was getting a bit frustrated with the standard of some peoples driving.
Here's a vid of the Cup from the pit wall, Sam's driving.
We completed our ARDS tests too, both passed and now just have medicals to do and get the licence application form sent off.
Got bit of post day checks to do today and then get the Cup back in the barn and get ready for Brands on May the 7th...
Still unsure whether to replace the front tyres on the Cup, they performed well yesterday and they still have tread bars showing, I'm taking the Cup to the CSCC fist race (for scrutineer checks) on the 14th so will leave them on and see what they say.
Great progress in driving mate. As I said at Brands your doing well, it takes time to gain the knowledge and get rid of the road driving habits
Look's great Pete :) Well done on both of you passing the ARDS test!
I have had exactly the same issue with my passenger side top mount although mine is the PMS kit. We have just lactated in place and marked it up so that we can see if it does start to slacken off again.
Who was running the trackday as that doesn't sound too good :( I'm guessing it was MSV because you did the ARDS at the same time.
Also just seen your previous update the false floor looks great and I like your solar panels ;)
Not posted on here before but well done on getting the license. BTW - I was in the White Cup (W11 CUP) having too much fun on the circuit!! :)
What steering wheel do you have? Saw a glimpse of it at Bedford last year (I think it was you) and it looks absolutely spot on.
Looks like an awesome day, drive by videos look quick!
Day was spot on really, they are getting better and better each time out, quicker and sounding good too!! Cheers Duffman.
Thanks Jay, might put in another cheeky day before Brands (if we can). In the rush forgot to practise starts (from when getting waved onto the track) and driver change overs....Though can try here and make a 5 second board and get Harry to shout go (or turn of the red torch) at some point after Scarlett lifts the 5 second board.
Cheers James, though isn't lactating something to do with breast milk, something you're not telling us all??? Yes MSV ran the track day, though driver error all the way really.
Hi clewsy, yes, did see you, in my rear view mirror (joking). Welcome to the forum and cheers. I did see a fair few Clio's mixing it up in the afternoon session, there ended up being quite a few Clios on track in the end.
Hi Skeeter, yes it was me and the wheel is just right....and here are the wheel details...in your thread, post 14....
My bad lol! First time I spelt it as Locktite and then went back and corrected it and it must of auto corrected to that lol! I meant to say we loctited it ;) (It just autocorrected it again ;))
No race number as yet, still away. Ready to come home i'm on my knees been up at 7 and run ragged every day so far....Harry & Scarlett are still wanting more...doh. Going to email Hugo see if we've been allocated a number.
