Just so its perfect is all. Just a light skim should do it then. I will probably get the valves re cut to whilst at it.
I think you can skim loads off. I read a thread that suggested 40 thou to get to 12.3 cr from a reputable (at the time) tuner. I guess the real answer depends on what you want to achieve.
http://www.cliosport.net/forum/showthread.php?195585-Compression-12-6-1
	Can I put oversized rings on the standard pistons?
Anyone notice the big burn mark on my flywheel?
Ok thanks guys.
If you go high comp pistons does that increase BHP on its own or do you have to do something else at the same time? Increase fuel flow or something? As I cant afford to go much higher otherwise I am fitting tons more ballast. I am already fitting cams to this rebuild.
Just mapping required. You should see a bit of a power bump. What cams are you fitting?
Just had a look, that's pretty scorched, is the blueing on both sides?
I got carried away and have decided to get the block rebored as number one and 3 bore have slight scuffs in them. The crank and shells look fine mind you. Can I put oversized rings on the standard pistons?
I have scrapped my idea of open verniers after finding this wedged near the timing belt under the cover LOL
This is why you dont put silicone anywhere near your engine when sealing covers etc, or if you do just a very fine smudge of the stuff.
So torque it up with old bolts and check crank moves and if its ok torque it up with new bolts?
I will torque using my torque guage and the then angle guage.
Are you familiar with how to use plastigage?
http://www.plastigaugeusa.com/how.html
My project thread
http://rejsa.nu/forum/viewtopic.php?t=43793&postdays=0&postorder=asc&start=929
ARP rod bolts need 42 lb/ft or around 58 Nm.
Crazy isn't it MarkCat are shocking for it from my experience and also what I hear! Hope you get sorted
I guess the thing for the cam's is to help time them up because they are the non-vvt ones they dont have the ability to use the normal timing tools do they?
Here are the pics.
What is this?
Verniers with annoying missing stud
Wow great list Mark! Glad they sent you the correct cam's
My tyre has worn the paint off the bulge in the same place so will copy your solution
