Russ_16v's ITB'd & Caged 182 Track Car (Was Crispy's)
  TrackCar & F30 330d
I'm back!!!!
I had been promising updates for a little while but it appears to be quite difficult to get much done when living in a different country to where the car lives!
I'll have to drip feed the updates as the Internet where I live is a bit sh1t.
So cutting a long story short the car now lives in my garage and when I poped home a month or so ago I thought i'd start here up. Started first time and was ticking over nicely, but for some reason the fuel line was dripping lots of fuel on to my alternator. So very quickly stopped the car!
I first drained the fuel tank by manually running the fuel pump.
Pulled apart the goodridge fuel fixing
And refitted it
Bought myself a new key as I'd sold my keys with my ecu! And filled up the tank again
Went to start the car and it decided to run like a dog and wouldn't idle and sounded like a Subaru!
Fuel did drub on the TPS so it's possiable damaged or there's just air in the fuel line!
When I come back in August I'll have to get Dan from 519 automotive to come work some majic and fix it.
  TrackCar & F30 330d
Bought some new track rod ends just to freashen up the steering
And also got my electrician cousin to come round and run electricity to the garage and put lights in.
So next job was to test fit my new studs and nut conversion just to make it easier to change the wheels.
Old very rusty wheel bolts!
New stud and nut
Studs put in (will lock tight them)
Wheel on
Then I can now measure how much I want to cut off
I'll actually have to try it with the Ultraleggers as they have the larger off set!
  TrackCar & F30 330d
After 3 months and no clean the car was very dusty and the new garage lights made the car look bad
So rolled it just outside and gave it a wash
The plastic windows had stuff growing in them
So I took the apart and gave them a clean
All clean so back inside to go on axle stands for another 2 months
Gave the wheels a good clean, still had the carbone Lorraine brake dust from the nurburgring all those years ago!!!
  TrackCar & F30 330d
After 10 pints I decided to do some retail theropy at probolt
So I used these with my new threaded rivit tool to attach my new central switch pannle
Measured, drilled and rivited.
And then attached my little switch pannle I made months ago. May not look amazing but it does the trick, and still needs the wires taping up
Just needs the names sticking on
All in perfect reach
Like I said it still needs tidying up but it's getting there
  TrackCar & F30 330d
Finally I removed the locking mech from the boot, I will bet cutting this bracket out next time.
New areo catches
The point where the fixing stud goes
And then before I knew it I had to go and catch my flight!
Short but sweet.
  BMW Z4
Liking the updates Chris :) Stop whining though, I built a complete race car remotely from Switzerland LOL (with your help of course)
  TrackCar & F30 330d
Yeah cheers guys, it's getting there!
The lights on the dash are indicators at the far sides. Alternator, shift light and I can't member what the other red light was for lol. The switches on the dash are,
Ecu
fuel pump overide for draing the tank
starter motor
Rain/fog light
And a few spares
Switch pannle to the left of me has
iindicators
windscreen wash bbutton
windscreen wipers
Manual Radiator fan (but the fan will actually be linked to the ecu)
Rear side lights
Windscreen demister
I'll maybe buy a proper dash at some point but for now this is good enought to be able to drive it.
  Clio 1.2
Just read this thread from start to finish, taken me about three days! Absolutely fooking love this car, has given me loads of ideas for when I get my 182 - I'm only 17 so currently only got a 1.2 :( I'm also hoping to work in Motorsport engineering but am looking for apprenticeship, although I do have place at Oxford Brookes with a conditional offer of BC which I will definitely get unless I really **** something up. 3 more weeks and then all my exams are done :)
  TrackCar & F30 330d
Oh wow - so you drive it without a rev counter? :|
Rev Counters weigh too much ;)
I'll set the shift light to come on at 7200rpm so i know i have a few more revs before i should change. Possiably could be a lot of Limiter hiting on my first trackday!
You'll pick it up in no time mate, I don't ever look at my dash apart from to look at water temp :) Good progress and can't wait to see it on track!
  182 Trophy #113
Reading this thread takes me back! The car was such a minter when you bought it, It's a completely different beast these days! Let me know when you're planning your next track day.
Think this thread deserves a little bump, one of the more interesting reads i've had on CS for a wee while.
Really love it when families are full of petrolheads, fortunately I have a very similar family - minus the huge house.
  TrackCar & F30 330d
I'm rubbish at updates these day!
but as some of you may know I did finish the car and I managed to get to Bedford on the 9th of Feb
i had a pretty bad tracking settings and with a combination of cold R888's and very skippy conditions it was a bit of a handful!
[vid
cutting a long story short I had to buy a new alternator and battery.
I carried out some tracking changes and finished off some other bits and went to Oulton park on the 26th of March.
Heres one of my faster laps chasing to very quick Homda Integras
I will post some pictures shortly of what's new!
Daniel
  Whichever has fuel
Your passenger needs a footrest! lol.
Car looks great, goes bloody well to! (I'm not going to massage your ego and comment on your driving. ;) )
  TrackCar & F30 330d
Fitted Areo catches to the boot
After my Bedford trackday where we found the battery was nackered i bought i new one!
I also found that the alternator was trying to make a run for it with the bolts comming out!!!!
This was my simple dash before i fitted my Volt reader
This is with the volt reader so i can see if the battery is getting charged or not!
I also sprayed the top part of the fire wall to stop the reflection on sunny days.
I started to sand the bonnet too at the clear coat was all funny. still needs work but its getting there
I also bought Icemans AST sportline 2 coilovers, which are insanely hard!
And finally i rolled my rear arches so i could pretend its a 80's Touring car
Before
After
Thats it for now! I'll try keep you up to date if anyone still cares lol
Greeny.
  440i + 182
Awesome car mate :) I remember when you were originally building this when I had my old black Clio, this has come on a long way, looks epic :) Hopefully ill cya at some tracks in the summer.
  TrackCar & F30 330d
I do notice my passengers pressing the imaginary brake peddle when coming to a corner! So maybe a footrest might give them something to press against lol.
Yeah i've had it quite a long time!! Be good to be on track with some more clios! I've got Oulton Park on the 25th of June with Easy track if your around!
Nice arches ;)
Oh yeahhhhhhh!!! Thanks again for the arch roller. p.s i've still not found my Natwest card reader! but i havnt forgotten!
Any thoughts on how i can get rid of some of the high speed understeer?
