Scott's Super Clean PH1 172 Project Thread
Re: My PH1 172
A little bit of an up date, so the new water pump is fitted along with new bolts and a new aux belt kit.
Ive replaced the leaking PAS pump along with an oil, filter, a set of spark plugs and the correct Renault coolant.. :D
Bought a few more bits from from Adam, new front fog lights and a slam panel rubber seal.
Re: My PH1 172
Thanks mate, its getting there. I have ordered the bulkhead trim (black felt behind the engine) its on back order so should be with me in 10 days or so.
I will also get the inlets, alt brackets and the other alloy bits powder coated at some point (prob in the winter)
Re: My PH1 172
Ouch bet that weren't all cheap mate. Keep up the work and this will be one hell of a ph1.
Re: My PH1 172
Fog lights fitted, so much better than the old ones.
Before.
After.
There was also a few bits around the car that i was not happy with.
The fuse box cover, yes its a small mark but it annoyed me.
So i bought a new one.
The boot trim.
The air filter housing is a pain in the ass the remove and re-fit so over the years its been scratched to hell.
I bought a new one and ive also got a black silicone Forge hose to fit so it will make it 100 times better to remove in the future.
And the biggest thing was the engine bay bulk head fire wall/heat shield thing which looked a right mess and the black stuff kept on coming off.
I had to wait 10 days for it to come into the country and i knew it was not going to be a nice job to fit but it just had to be done.
So tonight i started to strip down the engine bay down to fit the new engine bay trim, lucky enough my AC needs a re-gas as it had to be disconnected.
It was a bit tight but i got there in the end, once i get my inlets powder coated later in the year the engine bay will look great. :D
All removed at last.
So much better.
Re: My PH1 172
Nice one pal. Looks great :) nice to see it being refreshed.... I'm sure renault parts would think the same too!
See you went for a forge 90degree bend in the end. Any reason over samco?
Re: My PH1 172
Just read all through. love this, looks superb. :approve:
Good effort with the little things you've refreshed/replaced makes a big difference
Re: My PH1 172
Thanks Mark, i did see the Samco ones but being a bit dumb i thought it was only available in blue and tbh i think they are both the same just a name change.
After buying the Forge one (which was about £4 cheaper) i saw that the Samco also come in different colours. Derr!!
Re: My PH1 172
Good stuff mate. Slightly nuts but good effort! How much was the firewall? I either need to do mine or buy nimbus
OCD is a killer mate, the fire wall was £100 and a 10 day wait. You might be best buying the Nimbus.
Cheers for the comments. :)
Re: My PH1 172
I can see you buying a trailer for this soon ;) Great to see such passion and attention to detail on this car. Top work as ever, and jealous of your mechanical skills doing the alternator kit,
Re: My PH1 172
You're definitely on my list o people that I want to meet at CSS.
I wouldn't worry about the pressure being on. My sunflower won't be perfect for the day :(.
Re: My PH1 172
Cheers mate,
Its getting there, the Clio is my hobbie i guess that's all i do now im old and boring....lol
Yes its a fair weather car now, the aux kit and water pump was easy id never earn any money out of doing them as i take to long. I also did my own cambelt and yes i bought the Renault tools....lol
I just did the bits that play on my mind/bug me....:D
Re: My PH1 172
Ditto mate, bloody cars never are when you have bloody high standards.
Ill be with Sunglasses Ron, just hope we get a bit of sun. :)
Re: My PH1 172
The both door handles had cracked so i bought a pair of new ones but Renault had change the design so i also had to get the new type of screws.
Old type with the counter sunk screw which is the cause of the cracking.
The new design and screw.
Lots better.
Re: My PH1 172
I prefer the ph2 handles with the metal latch I changed mine to those ones.
Re: My PH1 172
I couldn't bring myself to fit PH2 stuff.....lol
​But the PH2 handles are quite nice.
Re: My PH1 172
Thinking the same, as mine are also cracked. How much are Renault charging, if you dont mind me asking? The car is looking amazing..! Looking forward to having a look at CSS :)
Re: My PH1 172
No not at all mate, they where £15 each + vat from Adam at Wolverhampton oh plus a few pounds for the screws.
Thanks for your comment, look for ward to meeting you to. :D
Re: My PH1 172
Bargain..! Thanks for that. See you on Saturday
​ :cheers:
Re: My PH1 172
Well after doing alot of work on the Clio i also bought a Cup spoiler, so it was off to Chris @ Autocrash for it to be painted.
Not the best pict as it was getting dark.
I then set about getting the car ready for CSS, i cleaned under the wheel arches.
Waxed wheels using AF Soul.
Also got a bit carried away and removed the AC pipe which i polished with the Megs metal polish.
I then gave the car a going over with AF Tripple with a black hex logic pad and my DA.
I then finished it off with AF Illusion wax, AF Revive for the plastic trims i also bought AF Tough coat and Gtechniq C2V3.
Ive only used the C2V3 on the bonnet.
Re: My PH1 172
Just seen this mate, car looks great, I am on the look out for a Phase 1, just hope I can find one as good. Don't worry about being 37 mate, I am 40 and probably look silly driving mine, but do I care NO, my mates who have driven my car fully understand the love for these little cars. Really wish I had of seen the car at Css.
Re: My PH1 172
I want this car in my life :( Such a credit to you mate! Very jealous, THE perfect Ph1.
I was going to ask how much the handles were, my driver's one is cracked so will replace both. Will be phoning on Adam friday to order along with a coil pack and leads!
